Installed Burly's, now the front?? (pics)
Old Feb 2, 2011 | 01:05 PM
83efi's Avatar
83efi
Drop it. If you dont like the look, put in a taller spacer. When you see the ghetto factory springs that come out and compare them to the spring going in, you will be glad you did even if you dont drop it much.
Old Feb 2, 2011 | 03:23 PM
bcmiles's Avatar
bcmiles
Originally Posted by lhgdale
What is the difference between the Burly front spring kit and the Progressive Drop in Kit?
The Burly front springs don't drop in. I called Burly and asked. Some minor dissassembly is required. The progressives drop it.
Old Feb 2, 2011 | 03:37 PM
jordanball33's Avatar
jordanball33
Originally Posted by jaysbobber
Just out of curiosity I have a question. I don't ride 2 up, but I weigh 250lbs. Will the Burley's do a good job for me or will they be bottoming out a lot?
i havent bottomed out yet. i weigh 200 pounds. and i also ride my girlfriend who is about 105. thats over 300 expecially if u add in helmets clothes and jackets. no problems to speak of from back roads to interstate
Old Feb 2, 2011 | 06:17 PM
83efi's Avatar
83efi
The Burly slammer kit springs DO drop in.
Old Feb 2, 2011 | 08:19 PM
bcmiles's Avatar
bcmiles
Did you install Burly or Progressive up front? The website says the kit does drop in, but I called Burly to verify and they said the forks would need to be removed and disassembled. Either way, the Progressive kit and Burly kit look the same and cost the same.
Old Feb 3, 2011 | 12:03 AM
wideglidebob's Avatar
wideglidebob
i slammed my rear and front i think its killer lowered, but as you can see we all have our opiions and ultimely lyou have to make the choice its a no brainer if u have have the part do it if you don`t like it undo it
Old Feb 3, 2011 | 09:54 AM
bigdaddy33's Avatar
bigdaddy33
Sounds good. Post up a pic so we can take a look.
Old Feb 3, 2011 | 10:12 AM
rc4fan's Avatar
rc4fan
I did the rear only and love it!
Old Feb 3, 2011 | 01:37 PM
02DynaDude's Avatar
02DynaDude
Hey BigD33, Good looking ride. This has nothing to do with lowering, but i was just talking to a friend about adding another rotor and caliper to the front... as i see you have done... How complicated was that? Does someone make a kit or did you piece it together yourself?
Old Feb 3, 2011 | 05:01 PM
83efi's Avatar
83efi
Burly slammer kit,front and rear. Pretty sure the progressive kit is identical. Burlys kit is a drop in and you can do it by just removing the fork caps, but I ended up taking the tubes to put in heavier weight fork oil.
