lost head light harness inside frame now what?
Old Feb 8, 2011 | 01:12 AM
Peter Black's Avatar
Peter Black
that headlight connector is a wile one! On a lighter note, just got done pinning out the headlight bucket, so I'M 50% done!
Attached Thumbnails lost head light harness inside frame now what?-unknown.jpeg
Old Feb 8, 2011 | 06:21 AM
8541hog's Avatar
8541hog
Originally Posted by Peter Black
Also tried pushing harness forward from under seat but that seems to me a no go; i'll have to try again tomorrow. thanks for the tips guys going to give it another try!
Don't just push the slack under the seat, you need to pull at the same time from the neck, it will feed right out that way very easily. You may need an extra pair of hands so 1 of you can push while the other gently pulls.
Old Feb 8, 2011 | 08:36 AM
JohnnyC's Avatar
JohnnyC
Pete,
Would a wire coat hanger, straighten out and with a small hook bent into the end, reach in the tube and hook onto the cable to aid in pulling it back up and through? Sort of like an electrician's "fish tape".
I've had the stupidest things slow down a project before too. My last challenge was a simple speedo cable installation. Had to lift the speedo assembly up to connect the cable to it. Discovered the trip odometer **** had a worn bolt head. I finally had to go to the hardware store and get a tiny #1 Philips to get a tiny bolt out it so it could be removed, and then the speedo would lift up to get to the cable connection. After getting that bolt out it had such bad head damage that it was another trip to the hardware store to find a tiny replacement bolt to go back in. A 20 minute tasked turned into several hours...Ugh!
Old Feb 8, 2011 | 08:57 AM
8541hog's Avatar
8541hog
Originally Posted by JohnnyC
Pete,
The whole harness is one unit in the frame, grab the wires that are sticking out and gently pull them while pushing the slack under the seat, don't try using a piece of steel with a hook on it, you run the risk of shorting another wire. This is VERY simple, push and pull.
Old Feb 8, 2011 | 09:41 AM
R_W_B's Avatar
R_W_B
Post
Hmmm this is an interesting one. I've never seen that much tension on any of my wires to do this.
If you cannot locate it at all by fishing around with your fingers then I do as the previous replies said and loosen just the front tank bolt (if you don't already have a tank lift) and stuff a towel under the front of the tank enough to gain better access to the plastic gusset under the frame neck. Then just slowly pull the whole mess out until you can either see or feel the unconnected connector. (Don't raise the tank much or your crossover tube could be in the way to much to get the gusset out)
On mine there is no slack under the seat. My harness is dead tight turning into the frame backbone. But you should be able to find it in the neck.
Good luck with it.
Old Feb 8, 2011 | 11:58 AM
Sharknose's Avatar
Sharknose
Something I learned when hanging the outer fairing on a road glide without removing the headlights. When I get frustrated with something, I walk away for an hour or so. More often than not, when I go back to it everything goes right into place.
Old Feb 8, 2011 | 01:32 PM
Fridge's Avatar
Fridge
R_W_B, I may be wrong but I think a lot of posters are referring to pre 06 bikes where the loom is really tightly packed into the spine of the frame.
Old Feb 9, 2011 | 06:22 PM
Peter Black
Good luck with it.
Well, I finally got it; the connecter somehow found its way an inch or two pasted the opening in the back bone, just under the tank! I used two window shims wrapped in a t shirt to prop the tank up enough, so I could pull the harness out. What a pain in the ***! I just want to thank you guys for all the great tips and words of encouragement!
Iceymike
Jan 23, 2017 02:50 AM
mike14_07
Jul 30, 2015 10:15 AM
05fxdxi
Jun 26, 2013 10:22 AM
jms428
May 27, 2011 10:24 PM
mjaw
EVO
Mar 14, 2010 03:07 PM
