What else can I do?
Old Feb 7, 2011 | 11:17 AM
hdbeggs's Avatar
hdbeggs
Default What else can I do?
My 1989 Low Rider is missing and spitting back thru the carb at all speeds. Here is what I've done so far:
Drain and replace fuel
Clean and put kit in carb
Replace compliance fittings
Replace spark plugs and wires
Replace coil
Replace VOIS
Run compression test(165 psi on both cylindes)
Can anyone suggest what to do next? I know that if I take it to the dealer, the first thing he will do is start replacing stuff I've already done.
Old Feb 7, 2011 | 12:11 PM
greenstreetbob's Avatar
greenstreetbob
Check for vacuum leaks. Are you sure the carb is set up right?
Old Feb 8, 2011 | 08:20 AM
hdbeggs's Avatar
hdbeggs
I have checked for vacuum leaks by spraying starting fluid in the carburator area while the engine is running. I get no increase in rpms. The problem started before the carb was ever removed, and I set it up the same as before.
Thanks for you help.
Old Feb 8, 2011 | 09:48 AM
blueangel73's Avatar
blueangel73
Are you sure you not running it to rich/lean?
Old Feb 8, 2011 | 11:08 AM
QehQeh's Avatar
QehQeh
Fuel filter?
Old Feb 8, 2011 | 11:51 AM
Sharknose's Avatar
Sharknose
When I had that happen it was the ignition module.
Old Feb 10, 2011 | 05:51 PM
83efi's Avatar
83efi
Timing?
Old Feb 10, 2011 | 06:55 PM
Phrogman's Avatar
Phrogman
Check your vent tube in the gas tank and ensure your gas cap is venting properly. I had a similar thing with an 86 Sporty once and the gas tank was vapor locking due to no venting.
You might also concentrate your investigation around the manifold instead of just the carb. A leak at the manifold to head interface can cause this as well. You mentioned the carb but said nothing of the manifold.
Old Feb 10, 2011 | 08:32 PM
lo-rider's Avatar
lo-rider
Originally Posted by hdbeggs
My 1989 Low Rider is missing and spitting back thru the carb at all speeds...
Can anyone suggest what to do next?...
Take it to a pro.
Old Feb 10, 2011 | 10:16 PM
roofer's Avatar
roofer
My 91 did that and it had jets in it for a lower elevation it went from sea level to 3500 feet and was doing what yours is doing so I did a stage one kit on it and jets and it ran great
