cutting old mid shifter shaft rod
Old Oct 7, 2006 | 01:46 AM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Default cutting old mid shifter shaft rod
the parts guy at my dealer mentioned a hacksaw that is like a rope, that you could use the cut the lever off from the behind the inner primary cover and then pull the rod. some one here said they did this with a reg blade, but that would take a while
Ever heard of such a saw?
Thanks
Old Oct 7, 2006 | 11:00 AM
mikec's Avatar
mikec
Default RE: cutting old mid shifter shaft rod
Use a Sawsall
Old Oct 7, 2006 | 11:32 AM
Mascman's Avatar
Mascman
A Dremel or grinder may be easier...and easier too.
What do you do with the holes? Do they make plugs for them?
Old Oct 7, 2006 | 12:52 PM
KeithB's Avatar
KeithB
ORIGINAL: Mascman
They do make a plug. but i may find one of those chrome oval plates that fit in the recess and glue it on.
Old Oct 7, 2006 | 03:53 PM
Matrix's Avatar
Matrix
I understand that there is a plug that fits on the outside of the primary, is there also aplug that goes on the inside?
I want to put some forward controls on my Street Bob. I don't want to have to remove the primary to remove the shift shaft,don't want to leave it in place behind a bolt like I've seen.
Has anyone cut their shift shaft to romove it, with out damaging anything, is this possible?
Thanks!
Old Oct 7, 2006 | 04:02 PM
The Punisher's Avatar
The Punisher
Do you really want to take a saw to a $15,000 motorcycle? Have the dealership put your forward controls on and they will remove the shaft they way it should be removed, by removing the inner primary cover. It is the only way to do the job correctly, you take a saw to your bike and screw it up your gonna pay for it to be fixed. Just have the job done right the first time, if the dealer screws somethinig up then they have to fix it.
Old Oct 7, 2006 | 05:36 PM
Matrix's Avatar
Matrix
True.
Old Oct 7, 2006 | 05:51 PM
redheadfred's Avatar
redheadfred
I agree , Think that one might come back and bit you on the a$$
Old Oct 7, 2006 | 06:49 PM
Naz_Man's Avatar
Naz_Man
ORIGINAL: bigdog46
That's for sure.... Why pay twice as much to have the hd shop fix your screw ups and install the controls or shaft, just pay them to do the controls or remove the shaft from the start! I wouldn't attempt to saw anything on my bike!!
my 2 ¢
Old Oct 7, 2006 | 07:27 PM
KeithB's Avatar
KeithB
ORIGINAL: Matrix
Thanks!
Riffleboy did. You tape everything off and use a taped up hacksaw blade and take your time by hand it works.
You only need the plug out side. Or get the chrome WG primary cover.
