black 11" progressives and rear turn sigs
Old Feb 16, 2011 | 04:16 PM
skygoddess's Avatar
skygoddess
I was referring to the 11" shocks about it not being a problem for me. I was asking if I should do the front end too or if it is okay without doing it. Like I said, I'm used to riding an old, chopped, hardtail Shovelhead so I'm used to a bit more of a rake. I was just wondering if Sumpnut had lowered his. I might just give it a try without lowering the front end and see how it handles for me. I guess I can always do the front end later if I don't like the way it rides.
Old Feb 16, 2011 | 04:29 PM
CRF's Avatar
CRF
Like I said it's up to you but you will notice the difference; .... for the price of a lowering kit ($70) and the 20 minutes it takes to install it I highly recommend doing it.
Old Feb 16, 2011 | 05:19 PM
Sumpnut's Avatar
Sumpnut
That should work for me. I don't ever carry passengers and I don't think I could or would pack enough stuff in my bags or strapped to the back that it would weigh that much. Did you lower the front end too or just the rear?
I lowered the front the same time with progressives drop in kit..first tried it with a 2" drop but did'nt like it..quick change to 1" and felt a lot better..that's how its staying..
Old Feb 16, 2011 | 05:51 PM
skygoddess's Avatar
skygoddess
So you ended up with 1" drop in the front and 1" shorter shocks? Both Progressive?
Old Feb 16, 2011 | 08:27 PM
norris's Avatar
norris
here is my street bob @ stock height and with 1.75" lowering blocks. I have no problem with bottoming out. But I will not let anybody ride on the back of the bike now. Hope this helps
Attached Thumbnails black 11" progressives and rear turn sigs-droid2-21311-140.jpg   black 11" progressives and rear turn sigs-droid2-21311-119.jpg
Old Feb 17, 2011 | 02:38 AM
lucky bob's Avatar
lucky bob
I'm kinda new to this ,so forgive me if this sounds like a stupid question but, it looks like the lowering block puts the shock on a bit more angle and kinda taking away from the natural plane it should travel in ...how is the ride quality compared to the 11 inch shock? I understand the factory shocks aren't the greatest to being with.
Old Feb 17, 2011 | 04:03 AM
DCLXVI's Avatar
DCLXVI
Yes the lowering block do angle the shocks more. The problem with that is that the stock shocks are crap really. Mine would bottom out all the time and I didn't have lowering blocks and it's a Super Glide which rides taller anyway. If you lower the back and not the front you change the rake on the bike. It will corner slower and require more effort to fall into turns. It will also increase straight line stability. Depending on your riding style one may suit you better than another.
Old Feb 17, 2011 | 04:06 AM
DCLXVI's Avatar
DCLXVI
As far as the spacers go you can have some made up from stainless steel or aluminum if you want something different. Also the '06 Super Glide came with som nice finished aluminum ones from the factory which I suppose you can order from the dealer. If it where me I would use the correct primer and rattle can the stock chrome ones.
Old Feb 17, 2011 | 08:58 AM
Sumpnut's Avatar
Sumpnut
Yea..fitted 11" Progressives 412's on the rear and up front Progressives DROP IN kit ..
Old Feb 17, 2011 | 02:07 PM
limp15000's Avatar
limp15000
I'm waiting on my 440 in 12.5 inches. I'll report back when I get them in a week or two
Bl0at3r
Sep 20, 2015 12:42 AM
Skitzer
Sep 17, 2013 12:47 PM
GlobeWarmer
Dyna Parts
Aug 6, 2013 09:11 AM
98fxd
Apr 13, 2007 01:33 PM
Bassman
Mar 31, 2007 09:22 AM
