Bar change question.
Old Feb 17, 2011 | 01:45 AM
phatman's Avatar
phatman
Default Bar change question.
First off I'm sure this has been beat to death but I don't have the time, patience or mobile data plan to search right now. I'm looking for advise on how to swap bars on a 09 Street Bob. I'm going with 12" R6C bars. I looked in my service manual and it says you have to remove the dash, fuel gage, lines & lift the tank to get to the wireing. Is there an easier way? Second question us what do u do with the brake reservoir while changing bars out. Do u drain it and re bleed the brakes or is there another trick? Sorry this is long & I'd appreciate any input. Thanks.
Old Feb 17, 2011 | 02:59 AM
Vins's Avatar
Vins
I can't imagine why you'd need to do all that just to replace the bars. The only reason you have to do that when pulling the tree is the wires are threaded thru them. Otherwise, the bars should swap without.
Old Feb 17, 2011 | 03:02 AM
Vins's Avatar
Vins
Oh...I read that you shouldn't let the reservoir flip upside down or you'll have to bleed the breaks. Don't know how air would get into the line, but that's what it said.
Old Feb 17, 2011 | 03:46 AM
HemiOrange's Avatar
HemiOrange
Lay some towels over the gas tank and headlight and have a few bungies handy. When you remove the right side grip and brake reservoir keep the reservoir as level as you can, use the bungies, if necessary, to accomplish this while you wrestle with the new bars. Two people can make this easier, but I always have done this alone.
The left side clutch lever and grip can dangle by their cables or wires while you concentrate on reconnection the right side brake controls and grip to the bars. Tighten them up enough to keep them from rotating before slipping on the other side.
When replacing bars and risers, I loosen the existing ones at the bottom stem and rotate the bars enough to remove and replace one riser for a new one. Then I mount one side of the bars to the new riser, remove the other riser and replace it. It all depends on what you are replacing with what. Just use your judgement.
If this sounds too complicated, forgive me for my poor description. A second set of hands can make this a bit easier. The goal is to keep the brake reservoir fairly level, as they do seem to leak if left dangling. The towels are to protect your paint from possible leaking fluids, to help hold parts from slipping off and to prevent metal to metal dinging. Personally, I use a thick quilted blanket over the tank and a towel over the headlight.
Old Feb 17, 2011 | 03:49 AM
DCLXVI's Avatar
DCLXVI
Well you have to do all that because you have internally wired controls. The only other way I know around that is to cut and splice the wires. Not my favorite way but if done correctly can be reliable. In my opinion by the time you solder and heat shrint all those wires you may as well just do it how the manual says.
Old Feb 17, 2011 | 06:35 AM
R_W_B's Avatar
R_W_B
Post
I've had my bars off a couple of times, as far as the brake master cylinder what I did was tie it off to the garage ceiling. Actually when I had to replace a tree riser that was stripped, I screwed a couple of hooks into the ceiling of my garage and then with rope attached a 3/4 inch pipe to the hooks.
I then have two ropes that I come down off the pipe to the handlebars. When I replaced the tree I did not have to remove (or let hang on the tank) anything. The whole handlebar setup just hung from the ceiling in place.
Old Feb 17, 2011 | 07:02 AM
evil-1's Avatar
evil-1
As HEMIORANGE said:
I would also cover your front fender just incase you may drop a wrench or socket. Good luck with the mod.
Old Feb 17, 2011 | 02:31 PM
phatman's Avatar
phatman
That's what I thought. I was looking for a shortcut but with my soldering skills it would take just as long to do that instead of undoing them at the connectors. I haven't wrenched in a while and tend to over think things. I'll sit and stare at it for longer than I work on it. Oh & while I'm at it do I need to get new grips or will the old ones come off? It says in the manual to cut one off, I think the left side. I just want to be prepared. Thanks for the help guys It's why I dig this forum.
Old Feb 17, 2011 | 03:13 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Check out these Instruction Sheets on how to remove
the master cylinder
and the switch housings
Use this link to find more info on removing the grips...
Old Feb 17, 2011 | 05:46 PM
R_W_B's Avatar
R_W_B
Post
Originally Posted by phatman
... ... do I need to get new grips or will the old ones come off? It says in the manual to cut one off, I think the left side. I just want to be prepared. Thanks for the help guys It's why I dig this forum.
You can slip the throttle grip off and back on the new bars. The left grip can be a bear sometimes and sometimes not. Usually if you get a thin flat screwdriver and lift up a little bit of the grip and spray WD40 under it, and keep working at it, it will come off. Then clean it up and dry the WD off it good before putting it back on. Sometimes they won't come off depending on how or what they were stuck on with, and you do have to cut it off.
