Compression release newbie
Old Feb 21, 2011 | 08:50 PM
DeneFXDWG's Avatar
DeneFXDWG
Default Compression release newbie
What's the deal with these things please? What is the cut off point in compression for requiring them to be installed 10+ perhaps? What does manual mean? You have to open them both up before cranking the mo mo over?
Sorry for the simple questions.
Old Feb 22, 2011 | 06:42 AM
Mike T's Avatar
Mike T
If you don't have dual plug heads, the heads have to be removed and they have to be drilled and tapped for CR's. Manual ones have a button you push on them before you crank it. When the engine fires up, they close.
Old Feb 22, 2011 | 07:32 AM
dyna rider's Avatar
dyna rider
Default CRs
Yes, if you are running 10/1 or higher compression, it just makes it easier on your starter to run them. The automatic ones open by themselves before cranking but require an electrical harness to the handle bars. The manuals have to be opened by hand. If you are running stock heads, they have to be drilled for them.
Old Feb 22, 2011 | 10:05 AM
DeneFXDWG's Avatar
DeneFXDWG
Default Thanks guys,
very helpful once again.
Old Feb 22, 2011 | 12:04 PM
bigdaddy33's Avatar
bigdaddy33
Take a look at the S&S manual compression release. One pull on the **** opens the release valves in both cylinder heads.
Old Feb 22, 2011 | 12:25 PM
JRK5892's Avatar
JRK5892
i have the push in type, they are awesome for allowing my motor to get turned over...w hen i do not use them the motor struggles to get over
Old Feb 22, 2011 | 12:43 PM
bikertrashchad's Avatar
bikertrashchad
Same here with the push type on HD MCR heads. Way easier to crank when they are pushed in.
TruckerXbones
May 9, 2019 02:06 PM
Hammy
Feb 22, 2011 08:39 AM
Rockrspud
Mar 12, 2010 07:29 AM
red devil
Exhaust System Topics
Nov 4, 2009 11:38 AM
maineultraclassic
Oct 4, 2007 06:13 PM
