Compression Releases
Old Aug 5, 2007 | 07:11 PM
maineultraclassic's Avatar
maineultraclassic
Default Compression Releases
Is it possible to install compression releases with the heads installed on the motor?
My starter is not liking hot restarts now, and I really think compression releases would fix the situation. But, I really don't want to tear apart the entire motor for just that simple install.
I had heard it was possible, but I wanted to check and see what people have to say.
Steve
Old Aug 5, 2007 | 07:22 PM
Road Glider's Avatar
Road Glider
Default RE: Compression Releases
We installed a set in the parking lot of a dealer 2 years ago in the middle ofour trip. A friend's Hipo motor started burning up starters. Piece of cake job....
Old Aug 5, 2007 | 07:28 PM
PhilM's Avatar
PhilM
Even though it "might" be possible, I would never attempt it on my own engine.
You gotta drill thru into the cumbustion chamber.... I know drill bits are designed to pull metal out, but what about tapping it? Metal shaving will make their way in... now way, dude!
Heads off.... springs???? [8D]
Old Aug 5, 2007 | 07:31 PM
Road Glider
Maybe these were different. The heads just had a plug to remove and we screwed in the H-D manual release valve. I think they were SE heads if that makes any difference...
Old Aug 5, 2007 | 07:34 PM
shooter64's Avatar
shooter64
Former Sponsor
Marine,
You could try the Spyke compression releases with the built in plug, they use ford plugs, I have used them several times on heads that we didnt want to drill and they do work. They had some problems when they first came out, but they got all bugs out, I am pretty sure.
Old Aug 5, 2007 | 07:40 PM
StreetglideOK's Avatar
StreetglideOK
Something to throw at you, food for thought. You mentioned heat when its hard to start. GM had alot of problems with starters failing due to heat, nicknamed a gm start. It worked fine cold, but after running a while, getting things good and hot, and then shut off, the exhaust heatsoaked the starter, and solenoid. Resistance increases with heat, blah blah blah. Long story short, they wouldnt start till cooled off. They started selling heatshields for them to help. Fords had remote solenoids, so they werent so prone to it. Curious if your exhaust is running on the hot side towards the starter?
Old Aug 5, 2007 | 08:47 PM
jeepster09's Avatar
jeepster09
ORIGINAL: PhilM
I couldn't agree more! What are you runnig for compression? I am at near 10 1/2 to 1 and don't need them. It's all in the tuning.
Old Aug 5, 2007 | 08:49 PM
jeepster09's Avatar
jeepster09
ORIGINAL: StreetglideOK
Steve....maybe you outa try different exhaust.......lol!
Old Aug 5, 2007 | 10:15 PM
hotpursuit's Avatar
hotpursuit
ORIGINAL: jeepster09
ORIGINAL: PhilM
me to running 10.5 to 1 and no releases.... i did have hard starts when warm but that was before i got a killer sert tune from a tuner down in Georgia
Old Aug 5, 2007 | 10:56 PM
Bryan TTM's Avatar
Bryan TTM
i run 10.8 to 1 with the 615/585 cams .... its in the cam timing .... put in the 615 and be done with it ... oh, i have em but dont use em ... and NO, you SHOULD NOT drill and tap the head while on the bike for reasons PhilM stated
