Even though it "might" be possible, I would never attempt it on my own engine.
You gotta drill thru into the cumbustion chamber.... I know drill bits are designed to pull metal out, but what about tapping it? Metal shaving will make their way in... now way, dude!
Heads off.... springs???? [8D]
I couldn't agree more! What are you runnig for compression? I am at near 10 1/2 to 1 and don't need them. It's all in the tuning.
Actually Jeep, I disagree. It's all in the cam timing imo. Those Kury cams are noted for being able to run high compression and start easy. ** EDIT: Sorry - Bryan beat me to it, should have read your post first. **
MUC - If you did do it with the heads on, I would get an air fitting adapter that is the same size as your spark plug hole and blast air into the chamber as you drill. Should minimize the amount of shavings that end up in the cylinder. Someone on HTT recommended that when this came up a month or so ago. Sounded like sound reasoning to me.
when I did my 88 to 103 I used my 88 stock starter for over a year. Then I started having kick back and hard starts when hot. My cure was to use the 1.4kv starter. One hit of the button and it's off and running.
I have thought about upgrading the starter to a bigger, chrome one..........but wasn't have any troubles until lately when the temps have come up, and really only on hot-restarts.
If the heads come off this winter...........I'm going to do the compression releases and maybe have the heads milled a bit more to get somemore compresion. I'm keeping an eye out for a deal on a pair of heads, I'll send them off to HeadQuarters to be worked on.......then maybe a pair of 575 or 0039 cams.
ORIGINAL: maineultraclassic
So if the stock is a 1.2kw, does a 1.4kw make that big of a difference?
This is something I'd be curious to know too.
On my old RG, that had a very hearty appetite for starter clutches, I tried a CompuFire Gen III "High-Torque" but was very disapoinited to find that it was more of a ratio change than more powerful starter. It did not spin the motor over as fast as the HD starter and I then ended up giong with an EVO style ring/pinion to get it spinning faster. It ultimately ate the starter clutch on the CompuFire too.
For anyone that has changed from the standard starter to the 1.6kv HD unit..... Do they "spin" at the same rate as the stock starter? Does the engine turn over as fast as it did before?
So if the stock is a 1.2kw, does a 1.4kw make that big of a difference? Or should a 1.6 or larger be used?
Steve
C'mon Steve, I took you for a Go Big or Go Home kind of guy. They make a 2.0kW starter, that's what you should get..... lol
Are you still running stock battery cables as well? I've heard some of the aftermarket cables acutally make a difference. I can't imagine you need to upgrade your starter for the compression you are running.
Another way to look at it: The cost of a new starter is going to be the same as a set of compression releases, decking the heads, and getting new springs installed..... might as well throw in a few more bucks for some cams right?
Thats the ticket, go for the full meal deal. I decided to start gathering parts to pull mine apart and do it. I've had a set of take-off heads in the garage for about a year just screaming for me to do something with them. I was going to pick up a RK as a 2nd bike and do a stroker motor and send those heads out for that project. I decided to skip that idea and put the Ultra under the knife again.
