Need a flatter profile heavy breather filter
Old Feb 22, 2011 | 06:01 PM
Pontiac's Avatar
Pontiac
Stage I
Default Need a flatter profile heavy breather filter
I have a 2009 Fat Bob with Screaming Eagle pipes, and cone-shaped Screaming Eagle K&N breather. I'm tall with long legs and the current set up causes me to angle my foot in to reach rear brake pedal. Looking for something flatter that will give me the same air flow. Suggestions ??
I'm new to this ....my first Harley! Loving it so far.
Old Feb 23, 2011 | 08:04 AM
HOGRIDA_06's Avatar
HOGRIDA_06
I like my Ness Big Sucker just fine. Doesn't come with a cover, but they are pretty easy to come by. http://cgi.ebay.com/ebaymotors/FITS-...Q5fAccessories
You also might try a longer brake pedal.
Old Feb 23, 2011 | 10:34 AM
dyna rider's Avatar
dyna rider
Default Position
If your tall and the air cleaner hits your leg, you need a seat that moves you back so your leg goes under the intake pipe. That's how mine sits and it is very comfortable. I have mid controls and highway pegs and either position is good to go.
Old Feb 23, 2011 | 10:39 AM
skinless's Avatar
skinless
I had the same problem. I took the foward control brake lever and bent it out some so I wasn't always rubbing my leg on the air cleaner. But here is another option.
http://cgi.ebay.com/ebaymotors/FORCE...Q5fAccessories
Old Feb 23, 2011 | 10:44 AM
TattoodCaptain's Avatar
TattoodCaptain
I have the Heavy Breather on the Dyna now. I did have the K&N Forcewinder. Same look but a lot more compact.
Old Feb 23, 2011 | 11:01 AM
Foxster's Avatar
Foxster
Went thru just the same issues when I got my FB last year. Tried of couple of different A/Cs and they all stuck out too far or else they were too small to flow much air.
What I did in the end was use a Revtech High-Flow Air Filter Kit that's really for circa 1990 carb bikes: http://www.retrocycle.com/CustomChro...rburetors.html
This is like the old HD 29008-90A kit that you can't get anymore.
This is no plug-and-play solution though. Needs some work to make it fit. The backing plate and black venturi ring is about all that's useful from the kit. I even replaced the filter with the K&N equivalent (HD-0600) though the one in the kit does fit fine. You need to get a throttle-body/carb mount bracket like the VT Manufacturing 31-0750 (https://masclassics.com//vtwin/0321.php) and some kind of breather kit, I used Krankvents though. Then you just need a suitable cover to bolt on top.
Here's how it looks:
Hopefully you can see its got a big enough area to flow well but that its slimline and doesn't even stick out as far as the exhaust heatshield.
Old Feb 23, 2011 | 01:25 PM
O.F.'s Avatar
O.F.
Do you still have your stock intake? Why not just buy a stage 1 filter and remount the stock setup (or pick up another)? That's one of the reasons I kept mine.
Old Feb 23, 2011 | 01:35 PM
Foxster's Avatar
Foxster
If the OP is like me then the stock A/C sticks out too much as well.
Old Feb 23, 2011 | 01:40 PM
nevil's Avatar
nevil
The stock football was a problem for my right leg. After switching to a Big Sucker and the plain round chrome cover I don't even realize it's there.
Old Feb 23, 2011 | 01:57 PM
O.F.'s Avatar
O.F.
So, today I've learned something new too. nevil...How much of a difference is there between how your stock cover sticks out and your Big Sucker?
OP....sorry for the hijack, hope it helps.
