Black bolt heads?
Old Feb 25, 2011 | 08:26 AM
Beerswimmer's Avatar
Beerswimmer
Default Black bolt heads?
I have a DWG with the black engine and want to blacken the bolt heads on it and the tranny. What should I use? I want it to blend, not be shiny.
Old Feb 25, 2011 | 09:04 AM
panic_fan's Avatar
panic_fan
I use a flat black paint pen to touch up all sorts of stuff.
Old Feb 25, 2011 | 09:36 AM
coachstorms's Avatar
coachstorms
yup, paint pen or epoxy touch up kit from home depot. wife's nail polish if your in a pinch.
Old Feb 25, 2011 | 10:00 AM
JRK5892's Avatar
JRK5892
i powder caoted all mine... but you can also use hot toppers, black automotive touch up paint works great and holds up awesome... but in the long run... you know me, powder is the way to go
Old Feb 25, 2011 | 10:17 AM
Gambler72's Avatar
Gambler72
If you paint them..either using automotive touch up paint or epoxy... what prep do you do to the bolt heads? anything? Even dumber question... do you pull them out one at a time or just paint them where they stand?
Old Feb 25, 2011 | 10:24 AM
RICHIEMACK's Avatar
RICHIEMACK
Home depo heat bareque paint for $10 take them out spray half an hour you are done flat black
Old Feb 25, 2011 | 10:52 AM
JRK5892's Avatar
JRK5892
bar b q paint will nto hold up... it cures at temp and without that it will not cure and they will chip and not last...
for prep i blast them... but i have just wiped down with denatured alch. and painted them right on the bike with touch up paint... works great and holds up!
Old Feb 25, 2011 | 12:23 PM
SouthpawHD's Avatar
SouthpawHD
I was told the prob with doing that is that the bolts then become a bigger size and can be much harder at getting out when needed.
Old Feb 25, 2011 | 12:51 PM
Motorcop540's Avatar
Motorcop540
I use Testor model paint most of the time and have had good luck with it. It has held up in the heat of the bike and being outside in the elemnets. I've used it on bolts all over my bike. Some I have painted after I took them off. Others I painted right on the bike depending on where they are and what I had to do to them. You can get primer in the model paint, as well as flat and gloss black and alot of other colors too. If you get to know a local auto painter too, they can match colors and textures for you in small quantities and give or sell them to you. Auto paint holds up well too.
Old Feb 25, 2011 | 12:53 PM
risdo's Avatar
risdo
^ I use Testor's, too. It's tough stuff... and I ain't built a model airplane for 40 years...
I use it on brackets, bolts, anything I want black. Easy to touch up if it gets scuffed.
