wide glide
Old Feb 25, 2011 | 05:40 PM
hotroddarin63's Avatar
hotroddarin63
Default wide glide
can someone tell me which one has the smoothest ride the dyna or softale?thanks.
Old Feb 25, 2011 | 06:01 PM
==ShaDoW=='s Avatar
==ShaDoW==
as I have a wideglide I would say this in a stright line its the dyna and in corners its a softail, this is a personal thing for me as I said I have a WG my brother has a softail, take that for what its worth (not much lol)
Old Feb 25, 2011 | 10:45 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
By smoothest are you asking suspension wise or engine vibration wise?
Old Feb 26, 2011 | 12:48 AM
USMC2010's Avatar
USMC2010
Coming from 10 years on a softail to my wide glide I would say the softail has a smoother ride, hands down. I don't regret my change though.
Old Feb 26, 2011 | 01:11 AM
j1mmy's Avatar
j1mmy
if you didn't look at it getting on, you probably wouldn't know any difference..wg sits a little higher
Old Feb 26, 2011 | 08:12 AM
mang0's Avatar
mang0
I have been told the dynas are better in the twisties...never been on a soft tail though....was I misinformed
Old Feb 26, 2011 | 08:29 AM
ghostrider69's Avatar
ghostrider69
Having owned both, I would have to say the Softail is smoother riding and better handling. In order to get the Dyna to ride as smooth and handle as well as the Softail money has to be spent on it. Stock for stock, the Softail, hands down. That goes for smooth riding and curves. You have to remember. The Dyna's swingarm is mounted to a rubber mounted engine and tranny, therefore you get lots of flex in the curves. The Softail's swingarm is mounted to the frame which helps it track through the curve a lot better and more stable.
Old Feb 26, 2011 | 07:09 PM
==ShaDoW=='s Avatar
==ShaDoW==
I was just going on what my ride does and what I see my brothers do on the same ride, as posted above mine is a WG his is a Fatboy Lo the dyna does move in the rear due to the angle on the shocks being different slightly, (in relation to the ground and the tire) mounted the same but different forces on each shock,
Healey11
Aug 9, 2014 09:47 AM
Tedjay
Sep 23, 2012 10:10 PM
Cheeto
Feb 24, 2010 10:22 PM
Schneider
Dec 1, 2009 10:54 PM
Lauro
Oct 5, 2006 11:10 PM
