Passenger peg mount Torx bolts - Arrrrgh!
Old Feb 26, 2011 | 09:39 PM
Romeo's Avatar
Romeo
Exclamation Passenger peg mount Torx bolts - Arrrrgh!
I'm having a hard time loosening/removing the passenger footpeg mount Torx bolts. The Torx hole in the bolt is so dang shallow, and the room you have to work in there is so tight that it's almost impossible to even put the Torx bit to them. Belt, fender, frame - everything blocks decent access to the bolts. In addition, I swear you have to have a couple of hundred pounds of downward pressure on the Torx bit to even begin to apply the torque necessary to loosen these bolts. I don't want to tear the whole rear end apart just to remove the mounts.
Anyone here ever removed your mounts? How'd you do it?
I don't know whose bright idea it was at the MoCo to use these bolts. Standard Allen heads would have been much better.
Old Feb 26, 2011 | 10:22 PM
SuperFastGlide's Avatar
SuperFastGlide
i got mine out with a good set of 3/8 drive torx bits , a ratchet and various extensions... pulled the belt gaurd of on the dive side also...
Old Feb 27, 2011 | 12:55 AM
firedyna's Avatar
firedyna
yep! what he said!
Old Feb 27, 2011 | 01:21 AM
==ShaDoW=='s Avatar
==ShaDoW==
replaced mine with standard bolts I to though it was a stupid setup,
Old Feb 27, 2011 | 01:54 AM
ric306's Avatar
ric306
yep, PITA, hardest is belt guard side. try putting a sodering iron tip on the bolt head, let it get hot , it will help release the lock tite. changed all mine to ss allen heads.
Old Feb 27, 2011 | 08:49 AM
jmeiers's Avatar
jmeiers
I had to remove the rear wheel and let the swingarm drop down to get mine off. Luckily, I am in the middle of swapping my wheels out so not a big deal.
Old Feb 27, 2011 | 10:19 AM
Rapter-10's Avatar
Rapter-10
I removed mine about 3 weeks ago..ive never had such a headache. but something that really helped me out was using a torch to heat up the bolt first once i heated it up i used some vise grips to break it free...the combination of little/no clearance, design of the bolt, and the loctite...makes it retarded challenging. I hope thats helped
Old Feb 27, 2011 | 01:53 PM
R_W_B's Avatar
R_W_B
Post
When you say it's shallow, makes me think it's Torx Plus and not Torx. There are two kinds (yea I could not believe it when I found out either).
I know for a fact on my H.D. forward controls the front brake pedal clevis is Torx Plus but the frame mount bolts (on the brace arm) are standard Torx. Crazy mixing it up that way, but that is the way mine are.
But yes definitely try heating up the casing to expand it and break loose any loctite that may be in there. If it is in fact a Torx Plus you might better get one or it could strip the head.
Old Sep 10, 2025 | 04:25 PM
CrackHeadBob's Avatar
CrackHeadBob
THANK YOU!!!!!
YeOldeStonecat
Aug 6, 2020 03:54 PM
jurakat1111@gmail.com
Jul 7, 2016 10:53 PM
johnnyglass
Mar 2, 2016 01:01 PM
AZRider62
2014-2024 Touring Models
May 15, 2014 09:32 AM
transam7969
Oct 15, 2013 07:22 AM
