Yet "another" floorboard question
Old Feb 27, 2011 | 05:10 PM
reissman's Avatar
reissman
Default Yet "another" floorboard question
Bike is an 09 Fatbob.
I have a set of the 2 orange floorboards and I was not totally happy with the location or the size. I am going to put them on the passenger pegs. For me I am thinking my best option is the Wyatt's. Here is my thoughts. Right now I have forward controls and a set pf mid pegs on. I measured the distance between the 2 and its 11". How hard would it be to get a set of floorboards that could just bolt up to end of the mounts?
Another option I was thinking is take the rubber off the pegs and weld them to the bottom of some floorboards?
Anyway... snow needs to melt
Old Feb 27, 2011 | 07:16 PM
gdt3's Avatar
gdt3
I have a pair of floorboards that I just took off my Wide Glide that are
8"x4 1/8" if you are interested. I believe they are quite a bit smaller than 2 Orange and just might be what you are looking for. They are super comfortable and your feet stay put.
Old Feb 27, 2011 | 08:06 PM
tscreener's Avatar
tscreener
Default home made.
I made some using the forwards and mids used 1/4 inch plate and used 3/8 by 1 inch for the mounting points then placed the plate where i wanted and welded it up covered with some rubber matting.
Attached Thumbnails Yet "another" floorboard question-2010-08-24-14.23.44.jpg   Yet "another" floorboard question-2010-08-24-14.24.01.jpg
Old Feb 27, 2011 | 08:16 PM
reissman's Avatar
reissman
thats what I am talking about. How did it work out for ya?
Old Feb 27, 2011 | 08:28 PM
U-234's Avatar
U-234
I made mounts for early Softail boards.
Old Feb 27, 2011 | 08:56 PM
reissman's Avatar
reissman
What kind of boards are you using on your street bob in your sig?
Old Feb 27, 2011 | 09:07 PM
SURFOR Chop's Avatar
SURFOR Chop
08FXDF43202 did a shade-tree engineer job with his that turned out well ... similar to tscreener's but using the standard floorboards ...
Here's his post from another thread ....
Originally Posted by 08fxdf43202
There's more than one way to skin a cat, here's mine...
RonnR did his along the same lines, too ...
Originally Posted by RonnR
Thats pretty much what I did with mine..
Road King boards mounted to the forward and mid mountings of the Dyna..
... RonnR did an in-depth how-to thread here ...
https://www.hdforums.com/forum/dyna-...on-a-dyna.html
I did the Softail floorboard route ....
R/
'Chop
Old Feb 27, 2011 | 09:18 PM
reissman's Avatar
reissman
I had seen the post by 08fxdf43202 but could not figure it out. But, I am sure I could do the ones RonnR put together. Thanks
Old Feb 27, 2011 | 09:29 PM
SURFOR Chop
I think it is just a rod the diameter of the mounting hardware with two bends ....
It either has a threaded end or has a bolt welded to the front end that goes into a peg extension ... he welded the rod to the floorboard ... if you look closely, you can spot the bead along the inner sides of the mounting points of the floorboard ....
then the aft end of the rod is inserted into the mid-control mount and the front end of the rod with the peg extension then just bolts up to the forward control mounting point ....
... as far as I can tell ....
Jaystn62
Feb 11, 2016 01:48 AM
wichitaks
Apr 19, 2014 09:08 AM
Tanker06
20
Jun 16, 2013 06:58 AM
adrock5151
Sep 22, 2008 12:46 AM
nardo
Jun 27, 2006 05:16 PM
