07 dyna battery removal
Old Mar 1, 2011 | 06:53 PM
whitey07's Avatar
whitey07
3rd Gear
Default 07 dyna battery removal
hi guys new here got a california 07 fxd want to remove charcoal canister,manual says remove battery before gas tank. when i remove the battery the alarm goes off any ideas ?probably a stupid question but id appriciate any help thanks
Old Mar 1, 2011 | 08:13 PM
lo-rider's Avatar
lo-rider
The disarming procedure is in your owners manual.
Old Mar 1, 2011 | 08:41 PM
johnsa28's Avatar
johnsa28
If you have your key fob near you you shouldn't have a problem, when exactly is it going off?
Old Mar 1, 2011 | 09:01 PM
whitey07's Avatar
whitey07
3rd Gear
The alarm goes off as soon as I disconnect the negative I have a shop service manual not the owners manual
Old Mar 1, 2011 | 10:08 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by WS6 Formula
Removing the vapor canister:
The single hose on the right side of the bike from the vapor canister goes up under the tank and doesn't connect to anything it is just a breather hose you can just pull it out.
On the left side of the bike you have two hose's coming off of the canister. The canister is labeled carb / tank, disconnect the tank hose and follow it up the frame to a little vapor valve, remove hose from the bottom of this little vapor valve and remove the hose. This is now your 49 state tank vent, you can also get the 49 state vent hose that connects to the vapor valve and runs up under the tank, it is in the Harley parts catalog (99439-06A) item 13 on page 90 P/N 27296-04A TUBE, VALVE TO ATMOSPHERE and a retaining clip item 7 P/N 10113 CLIP, DOUBLE HOSE.
Disconnect the carb hose from the vapor canister, this line goes up the frame and under the tank to a connection behind the top left side of the air cleaner, it connects to the intake manifold, disconnect and put a cap on the port of the intake. (In the Harley parts catalog (99439-06A) on page 20 they list a cap plug item 21 P/N 90383-98 CAP PLUG, INDUCTION MODULE that might be the one to use.) This hose is difficult to remove, I took off the rubber hose from the plastic tube by the intake and pulled the hose out from the front of the tank and broke off a clip that supports a harness that comes out of the bottom of the tank, but I was able to ty-wrap that harness to another harness under the tank near the frame. If you cut the plastic tube end off that has the ridge, it will not hang up on anything and it will just slide out.
The vapor canister bracket has a clip that you depress and then the canister can slide off the bracket. Loosen the two allen head bolts that hold the bracket on to the frame, remove top bolt then rotate bracket and put the bolt back in and tighten it down, then remove lower bolt and bracket, reinstall lower bolt and tighten it down.
toku58
May 17, 2016 03:36 PM
RafiHarley_1903
Jun 22, 2010 07:16 PM
freebyrd
Nov 8, 2008 09:06 PM
donivan3
Jan 28, 2008 02:11 PM
Hog_fever
Dec 7, 2005 12:37 AM
