Pulley installation
Old Mar 2, 2011 | 09:12 AM
p51bombay's Avatar
p51bombay
Default Pulley installation
I'm installing a billet pulley on the rear wheel using the HD chrome sprocket hardware kit and am finding the instructions in the hardware kit different to the service manual.
Hardware kit says:
- Tighten bolts to 23ft/lbs and an additional 60 degrees rotation.
Service manual says:
- tighten bolts to 60ft/lbs,
- back off 180 degrees
- final tighten to 77-83ft/lbs
So which is correct? The first doesnt seem like much - even with red loctite.
Old Mar 2, 2011 | 10:12 AM
8541hog's Avatar
8541hog
First off, how long are the bolts? Cast wheels or spokers?
I always use the torque settings in the manual on this one, usually 80 ft/lbs
Old Mar 2, 2011 | 06:41 PM
p51bombay's Avatar
p51bombay
They are about 4" long
Meant to post this in the general forum - could mod delete this one?
Old Mar 2, 2011 | 06:48 PM
R_W_B's Avatar
R_W_B
Post
Hardware kit says:
Yep that's a classic difference between HDs manual and part installation kits.
I'll bet they both come out pretty much the same. Once something reaches torque it doesn't take much more turning to get higher quick.
You could take both sets of intructions to the dealer and ask them to give you a decision.
Seventy4blazer
Feb 12, 2016 12:23 PM
p51bombay
Mar 4, 2011 12:28 PM
tlb
May 9, 2009 08:31 PM
disom007
Apr 2, 2007 03:33 AM
cwilks
Dec 15, 2006 11:32 PM
