Changing fork oil "by the book"
Old Mar 2, 2011 | 12:17 PM
O-Town D's Avatar
O-Town D
Default Changing fork oil "by the book"
I replaced the std fork oil on my F-Bob yesterday afternoon with the SE fork oil, using the procedure outlined in the SM. Two things I noticed:
First, the OEM spacers that preload the springs are 8" long paper-thin tubes that just don't look like they belong in 49 mm forks. I replaced those with sturdier 1-1/4" ID x 1-11/16" OD pvc pipe that I carefully cut down to 6-3/4" to drop the front end a tad.
Second, at the bottom of the right side fork is an axle cap secured by two 5mm allen bolts. That cap is machined flat on one side so that when bolted to the fork tube there is no gap, while on the other side there is a "cast in spacer" that allows for a small gap after proper torque is applied. The SM is very clear: the flat side faces the front, and the spacer side faces the rear, but the cap on my fork had been installed exactly the opposite by the MoCo. Hmm. I decided to reinstall the cap "by the book" and hope for the best.
It's raining now so don't have a chance to test the effects of the SE fork oil, but pretty confident it will yield the same good results as when I did this on my old FXR. Ride safe, guys.
Old Mar 2, 2011 | 12:25 PM
SuperglideKen's Avatar
SuperglideKen
So do you see or feel much differrance between the stock oil and the SE oil?
Old Mar 2, 2011 | 12:59 PM
JRK5892's Avatar
JRK5892
i am not a fan of SE fork oil i recomend Spectro 15 w in our bike s
Old Mar 2, 2011 | 01:15 PM
rockon's Avatar
rockon
Really wish there was an easier way to do this...
Old Mar 2, 2011 | 03:08 PM
O-Town D's Avatar
O-Town D
SuperglideKen - "So do you see or feel much difference between the stock oil and the SE oil?"
Bad weather is forecast until Friday - as soon as it clears and the roads dry up I'll go for a ride and post my impressions.
PowderPro - "I recommend Spectro 15 w..."
Will give Spectro (and other brands) some thought at my next change.
RockOn
- "wish there was an easier way to do this..."
Definitely agree with you on that - I miss those drain screws that my FXR had on its forks. But the tedious and time-consuming process does allow an owner to get "up close and personal" with some of the parts and workings of the bike that he /she would otherwise not pay attention to. In my case, as stated in the original post, I discovered something that needed correction, so I benefited by draining the forks "by the book."
Old Mar 2, 2011 | 10:23 PM
HemiOrange's Avatar
HemiOrange
There is an easier way, even Brian at Ricor confirmed my thoughts on it as their chosen method.
Suck that stuff out. I took an 18" long piece of steel automotive brake line that I had lying around, attached some fuel hose to it and used an old gear oil extractor (looks like a huge syringe) to suck it out. The small diameter brake is to reach the bottom of the forks and around any internals. A Mityvac would also work as a vacuum source, even a turkey baster.
Old Mar 3, 2011 | 11:36 AM
markrumsfield's Avatar
markrumsfield
wouldnt shortening the spacer result in even more front end dive under braking than stock?
Old Mar 3, 2011 | 11:53 AM
slider1156's Avatar
slider1156
Yep you will have more dive, Less preload on the spring
Old Mar 3, 2011 | 03:35 PM
O-Town D's Avatar
O-Town D
Was able to take the bike out on an errand run earlier today to determine the effects of the SE fork oil change and here are my impressions: there is a slight but noticeable reduction in fork "mushiness," and steering response seems to be a little crisper. Ride comfort has not been adversely affected - still fairly smooth. I need to take a much longer ride on various surfaces with more twists and curves to fully gauge the pros and cons concerning SE fork oil, understanding that the Dyna chassis does have certain limitations, but for now I am satisfied with the results.
You are absolutely correct, but my expectation is that the heavier SE oil will "slow" down the compression rate to partially offset the drop in spring preload. No worries, I can always cut a new spacer/add washers to increase the preload, or better yet, get a set of performance fork springs to really bring the front end "up to speed."
Ride safe, guys.
pgilbert689
Jun 30, 2018 07:30 PM
Misbehaven
Feb 22, 2013 06:49 PM
JayDee5150
Aug 3, 2009 05:01 PM
crepe
Aug 20, 2008 01:26 AM
DGlide04
Jun 13, 2007 12:33 AM
