Wheel Alignment - DIY or Pro?
Old Mar 5, 2011 | 08:04 PM
USMAMule's Avatar
USMAMule
Default Wheel Alignment - DIY or Pro?
I am looking to align my rear wheel. My Service manual calls for Harley "wheel alignment plugs but the concept doesn't seem to require special tools. What have people used? Or is this something better left to a pro?
Thanks in advance,
USMAMule
Old Mar 5, 2011 | 08:25 PM
trip20's Avatar
trip20
You talkin about aligning rear wheel after a tire change?
I use a bent piece of hanger with a zip tie that I slide up/down to measure axle on both sides. Got the idea from someone on the forum - too long ago to remember who.
Old Mar 5, 2011 | 08:37 PM
blacknsilver's Avatar
blacknsilver
There is couple threads about alignment tool:
https://www.hdforums.com/forum/dyna-...t-problem.html
https://www.hdforums.com/forum/dyna-...ment-tool.html
Old Mar 5, 2011 | 08:46 PM
thedonthere's Avatar
thedonthere
I use a tape measure.....works fine
USMAMule's Avatar
USMAMule
Default 10-q
Thanks guys that was just what I needed! I knew I could count on the good people of the forums. Now for curiosity's sake - how about the front wheel?
USMAMule
Old Mar 6, 2011 | 12:37 AM
dsiltman's Avatar
dsiltman
+1 tape measure works fine.
Old Mar 6, 2011 | 09:05 AM
tscreener's Avatar
tscreener
USMAMule
Front is not adjustable.
Old Mar 6, 2011 | 09:38 AM
8541hog's Avatar
8541hog
It does however need to be aligned left to right, for this follow your manuals procedure. If you don't get it right you will end up with some stiction on the front forks.
The hole in the end of the axle is what is critical, not sure on other models, but on my WG if you go by sight, it will be wrong.
Old Mar 6, 2011 | 10:37 AM
USMAMule's Avatar
USMAMule
Wouldn't that alignment (front wheel) be controlled by the spacers? I knew it wasn't adjustable the same way the rear is.....Just checking for safety's sake after winter mods.
USMAMule
Old Mar 6, 2011 | 11:27 AM
8541hog's Avatar
8541hog
USMAMule
Actually on mine the right side spacer does not touch the lower fork, which is why I said don't go by looks. It butts up to a shoulder on the axle, which is why you have to follow your manual on that one, not sure how yours is.
