Tell me about a Dyna
Old Mar 6, 2011 | 12:33 AM
tandt's Avatar
tandt
Default Tell me about a Dyna
I'm looking for a ride to replace my Nightster. I am looking for a bit more suspension, a bit more power, a bit more bike overall. Seems like a Superglide is a natural step, but I can't say I've ridden one. I am a bit over 6 feet so I'd need forwards, an easy mod as I'm pretty sure the Super Glide and Custom have mids, as did my 1200N. The Dyna has a really classic look and I like them a lot.
So...... from those who know 'em best - what's the best points on a Dyna Glide?
many thanks
Old Mar 6, 2011 | 01:06 AM
lo-rider's Avatar
lo-rider
The Dyna is the hot-rod of Moco's V-twins, the big motor from the touring bikes, coupled to the lighter Sportster front end, producing a bike way lighter than the tourer, w/ Sportster-like handling, and much more versatility. Plenty of bike for 2-up or carrying loads of gear.
Rent 1 for a day to see how you like it.
Old Mar 6, 2011 | 01:09 AM
daurwid's Avatar
daurwid
I think the Dyna fits all the points you ask for:
More suspension, yes, but not much more.
More power, yes, but 1200 to 1584, so a little more
More gas tank.
More weight.
Engine on Sporty is rubber mounted as is the Dyna so a similar feel between the legs. IMO, the dyna is not as "top heavy" from the peanut styled sporty gas tank therefore providing easier balance, stability and handling. But again that's a personal opinion.
I skipped over the Sportster line in favor of the Dyna. I felt like the Honda 750 I used to own was more bike than the Sportsters.
I recommend you go test ride some used ones to get a feel for the difference.
Old Mar 6, 2011 | 01:24 AM
JPL17's Avatar
JPL17
If I was you, I would take a look at the Fatbob. As you know, its a DYNA, comes with the forward controls and is considered the best handling bike in the line up. In the early 90's I had an FXR that I absolutely loved because it handled like a dream, hauled *** and fit me perfectly. I wanted the closest model to that FXR and decided the Fatbob was it and its pretty darn close. I also have a Sporster (the 48) which I love for bangin around town but anyway...good luck with whatever you decide.
Old Mar 6, 2011 | 01:33 AM
maxxod's Avatar
maxxod
Small correction....the Dyna line has not shared the front end with the Sportster since 2005. In 2006 all Dyna models were built with a new mid-glide front end with 49mm tubes, which is shared with some of the Vrod models and the Rocker.
The FXDF and FXDWG have wide glide trees with the 49mm tubes.
You cant go wrong with a Dyna......
Old Mar 6, 2011 | 03:15 AM
rockon's Avatar
rockon
Same motor as the other big twins but lighter and better handling.
Old Mar 6, 2011 | 03:28 AM
HemiOrange's Avatar
HemiOrange
Everyone's going to argue for their particular Dyna, but any of them will do. Bars can be changed, forwards installed, et al. If you want a Dyna to carve a turn, you need suspension, not some shorty shocks that can't absorb a hit, but something with some travel. This will also sit the bike up high enough to actually lean over into a turn without touching metal to pavement.
To really make the Dyna become a hotrod, just do an engine build.
Mine is set up about as good as I could get it to be....for now. I can speed up for R/R track crossings as they don't even register, I can out accelerate any stock or stage 1 Harley, I can ride all day at 80+ MPH, ride two up with saddle bags and luggage, even do wheelies. My old sporty couldn't to any of the above.
It really doesn't matter that my bike started life as a lowly Superglide....I just changed it.
Old Mar 6, 2011 | 03:35 AM
icebite1's Avatar
icebite1
I also would suggest the Dyna Fat Bob as it already has the foward controls and a wider front and tire. Pics are of my FXDF befor and after i triked it.
Attached Thumbnails Tell me about a Dyna-img_0272_1.jpg   Tell me about a Dyna-img_0283.jpg
Old Mar 6, 2011 | 07:10 AM
AFMM3's Avatar
AFMM3
These replies have some of the most honest answers, without bragging, that I have seen in a while. They are worth reading carefully. My own 2 cents: Feels more substantial, wider, smoother and more comfortable. Power will feel like there is more but acceleration (stock) is about the same. Center of gravity feeling lower will be a dramatic change.
The Dyna line is sometimes thought of as a blank slate where you can go in many directions. The bikes accept radical changes easier than most. Also the Dyna line is much easier to perform you own maintenance on than the sportster line (more room).
P.S. My signiture picture is a Dyna Street Bob meant to resemble a 1960 Duo-Glide.
Old Mar 6, 2011 | 07:13 AM
billycouldride's Avatar
billycouldride
the dyna hums along comfortably on the highway at 80 mph, my sporty at that speed was more like a chainsaw.
one of the first things i had to do to my 05 sportster was to swap out the suspension to make the ride tolerable, now, i am still riding the dyna stock , and liking it.
the 5 gallon fuel tank is a big plus too.
i don't consider my fxdc to be 'sporty', but its still fun on the backroads, and it can cruise them, or the highway all day long.
