Help! easy bracket problem
Old Mar 13, 2011 | 01:37 PM
lukemc7's Avatar
lukemc7
Default Help! easy bracket problem
Well Ive got my bike all apart in the garage and im trying to install the easy bracket kit on it. problem is the "docking posts" do not fit into the rear fender strut and without fitting into the holes none of the bolts are long enough. I have verified the part number of the kit with my make and model and its supposed to be correct. Has anyone installed these and had to drill or reem out their fender strut?
If so i wouldnt call these easy brackets. Tried calling the company but of course they arent open on sundays and I will be out of town for a week starting monday afternoon.
Please help.
Old Mar 13, 2011 | 01:54 PM
SC-Longhair's Avatar
SC-Longhair
am I to assume you have the detachable backrest based on what you've written? if so, did you order the correct EZB part number for use with a detachable backrest?
{EDIT} A moment spent on Google returned this: http://www.easybrackets.com/pdfs/EB-...D-BACKREST.pdf
Old Mar 13, 2011 | 02:06 PM
lukemc7's Avatar
lukemc7
Default easy bracket
No i have a hardmount sissybar and the kit says its able to be used with one as it is mounted inside of the fender strut.
in the two pictures are the docking posts. the first picture I highlighted the areas that in their diagram go inside the existing fender strut holes. the second is a picture of it next to the hole. The holes are close to the same size as the posts I would guess about 1/16 smaller.
*Edit* I think they gave me the docking posts that are for use with a detatchable sissy bar but the rest of the kit was the one I ordered. Looking at videos on youtube the ones without a sissy bar do not have the parts i highlighted in my picture.
Attached Thumbnails Help! easy bracket problem-img_20110313_135812.jpg   Help! easy bracket problem-img_20110313_135753.jpg
Old Mar 13, 2011 | 02:19 PM
SC-Longhair
That may very well be...that male end looks like it could fit inside the docking point for the detach. hardware.
Old Mar 14, 2011 | 03:53 PM
Skyking75's Avatar
Skyking75
Default Contact Esay Brackets
I had some issues with the bolts I received as well. Just give them a call and they will send out what you need for free. They did that for me. Very easy to work with.
866-521-3024
Old Mar 14, 2011 | 05:09 PM
parts eeter's Avatar
parts eeter
Edited cuz I had a brain fart....
Old Mar 14, 2011 | 07:26 PM
lukemc7's Avatar
lukemc7
Default got it
Got it all figured out, I talked with Bob a tech guy last night he was a big help.
Look for a review after I put a few miles on em.
Scorpio49
Sep 12, 2020 09:15 AM
HD28
Mar 21, 2015 05:22 AM
BlackMarshmallow
Sep 12, 2011 09:12 PM
kevdog
Jul 15, 2011 08:11 AM
HDBRATT
Sep 7, 2009 01:40 PM
