HD got me again...
Old Mar 16, 2011 | 10:55 PM
Rapter-10's Avatar
Rapter-10
Default HD got me again...
So I finally put on my SE a/c on the Bob. Turns out the kit didnt come with a peice that is mentioned in the directions. Its the self adhesive clip that goes onto the random plug in. The plug was originally just hooked on the back of the stock cleaner, but not really plugged into anything. Anyone run into the same problem with the kit, and if so what did you all end up doing to secure the plug?
Thanks alot guys
Old Mar 16, 2011 | 11:07 PM
1BadAssBob's Avatar
1BadAssBob
Zip tied mine & tucked it away.
Old Mar 16, 2011 | 11:09 PM
sacto95827's Avatar
sacto95827
ditto
Old Mar 17, 2011 | 12:42 AM
p51bombay's Avatar
p51bombay
Zip tied mine to the TB as well but I'm interested in this mystery part - which kit do you have? The ness kit doesn't come with it.
Old Mar 17, 2011 | 01:22 AM
dtone72rss's Avatar
dtone72rss
Just hangin
Old Mar 17, 2011 | 02:30 AM
Foxster's Avatar
Foxster
Its not a very good part anyway. Mine fell off after a few days and so I zip-tied the plug to the throttle body like the other guys.
Old Mar 17, 2011 | 08:57 AM
DCLXVI's Avatar
DCLXVI
Zip ties are the new duct tape.
Old Mar 17, 2011 | 09:06 AM
osb's Avatar
osb
That's really sad you had to zip tie a $200+ part.
Old Mar 17, 2011 | 09:42 AM
08fxdf43202's Avatar
08fxdf43202
I clipped the plug off and tucked the wire up into the harness sheth.
Old Mar 17, 2011 | 11:06 AM
Foxster's Avatar
Foxster
You have to be a tad cautious of that on international models though. On those models that plug goes into a sensor on the stock A/C and if you removed that A/C then you have to fit a special gizmo into the socket to stop the ECU from throwing error codes.
