street sweeper?
Old Oct 15, 2006 | 01:13 PM
Ash's Avatar
Ash
Default street sweeper?
All you guysout there with street sweepers do you have any problems with the heat shields vibrating? All my bolts are tight because I checked them several times. I've had the sweepers on for about 2000 miles now and when I run the rpms up, say 5mph+ over where you would normally shift they make all kinds of noise. I also tested them in idle, and at about 3/4 throttle they rattle so loud it overtakes the engine/exhaust noise itself. anyone else notice this?? could it be sonthing else that created them to rattle like they do?? Im going to contact samson eventually but I wanted to know if anyone else is experiencing what I am! Thanks
Old Oct 15, 2006 | 01:24 PM
hd2000's Avatar
hd2000
Default RE: street sweeper?
If i remember correctly samson had a problem with the heat shield clamps breaking.
Old Oct 15, 2006 | 09:16 PM
hammerhd's Avatar
hammerhd
I have not noticed this as a problem on mine.
Old Oct 16, 2006 | 02:12 AM
kimo's Avatar
kimo
Ill pay closer attention seems like i noticed some rattle but not sure from where. ill post back around the 23 of oct. gonna be out of town.
Old Oct 16, 2006 | 05:11 AM
CraigC's Avatar
CraigC
Are these BG3's on an `06 or `07 or an older version?
Old Oct 16, 2006 | 05:14 PM
Ash's Avatar
Ash
BG3's on an 06!
Old Oct 20, 2006 | 12:52 AM
Ash's Avatar
Ash
Well I pulled the exhaust, and after inspection I found that one of the welded tabs from the heat shield to the actual pipe was broken. Called samson and I must go through the motions of sending them the entire exhaust for inspection. Then they will let me know if they'll replace it. so hopefully they stand behind their work, because I only had the system on for 3months and about 2000miles for $400!!! So I'll be bikeless for a few weeks, good thing winters around the corner!!!
pjim
Feb 7, 2015 06:05 AM
mikeo33y
May 18, 2013 11:32 AM
HemiGlide69
Oct 31, 2010 07:27 PM
Deepsouth251
May 25, 2009 02:38 PM
SamStone
Jul 21, 2006 01:39 AM
