Shorter Shocks on FXDWG
Old Mar 20, 2011 | 09:40 PM
cavediver520's Avatar
cavediver520
3rd Gear
Default Shorter Shocks on FXDWG
Hi everyone, new here and have a question. I have done a fair amount of searching but havent found the info i am looking for. What type of modification and how much is needed to do to the rear fender to use 11" Progressive shocks. I have read that these shocks will lower the rear about 2". Is this true? Thanks in advance for the help.
Old Mar 20, 2011 | 09:56 PM
WideGlideRide011's Avatar
WideGlideRide011
im running the burly 10.5 inch shocks in the rear on my WG and I only had to remove my belt guard....only problem i have is that is rubs the tire only on real hard bumps like a hard speed bump hit or a BIG pothole....nothing to serious though....haven't had any problem with the caliper bleeder port hitting either
Old Mar 20, 2011 | 10:17 PM
jshull's Avatar
jshull
i have a used set in the classifieds....
Old Mar 21, 2011 | 05:51 AM
cavediver520
3rd Gear
Thanks for the replies guys, Hey jshull, i looked in the classifieds but did not see them. Can you send a link to the add? Thanks.
Old Mar 21, 2011 | 07:14 AM
rounder's Avatar
rounder
the pre 06 wideglide the fender will rub the belt guard just in front of the your shock. Personally, I would not go lower than 11.5". Look at Ricor shocks, or for chrome/polished shocks, works street tracker shocks. they'll be made to your rider weight, ride 1000x better and not cause bottoming out dump truck ride issues. personally I would not go lower than 12" shocks myself. I have 12" shocks on my bike and it came with the 12 5/8" shocks. Makes a very noticable difference in height without causing issue with ride, handling, 2up riding.
james4b
Nov 20, 2015 04:35 PM
Devchonachko
Dec 21, 2014 06:51 AM
cnbcook
Mar 21, 2013 11:18 AM
thewholehog
Mar 14, 2012 08:27 PM
DimeBag
Aug 4, 2009 07:19 PM
