Things just fly off.
Old Oct 16, 2006 | 12:21 AM
GeorgeJ's Avatar
GeorgeJ
Default Things just fly off.
2500 miles into my "new" 01 fxd and I really like this bike. But - things (after market of course) of a habit of flying off. So far I lost 4 head bolt covers and one seat hold down screw. Lock tight blue and both but they fly off. I can live with it. Just wondering if any one else is having this much fun.
[IMG]local://upfiles/15327/039509A8E2194E00A726175CE68566FF.jpg[/IMG]
Old Oct 16, 2006 | 12:27 AM
redheadfred's Avatar
redheadfred
Default RE: Things just fly off.
Thats nothing man , I had a brand new set of s&s slip ons shake off at 40 mph . I will never forget that . Red locktite all the way now
Old Oct 16, 2006 | 12:47 AM
GeorgeJ's Avatar
GeorgeJ
Funny you mention that - I have to re-tighten my SEII slipons after everyride. They slip back about 3/4 of an inch each ride. I'll keep a closer eye on them now.!
Old Oct 16, 2006 | 12:50 AM
mud's Avatar
mud
ORIGINAL: GeorgeJ
If you are having that much trouble with the pipes,
you may not be tightening them enough.
Or, maybe you should just go ahead and run a screw in.
mud
Old Oct 16, 2006 | 01:07 AM
GeorgeJ's Avatar
GeorgeJ
Clamp is snug. Don't want to gorilla it any more. I was going to losen it up and run a thin strip hvac foil then slip the clamp over and retighten. Maybe the clamps stretched a bit. If that doesn't work I'll give the screw a shot. Thanks for the advice.
Old Oct 16, 2006 | 01:23 AM
Whiffleboy's Avatar
Whiffleboy
Do you have them torqued to 60ft/lbs? On first install, I didn't torque, tightened them to [what I thought was] very tight and they moved a good 1/2 inch. A week later I torqued them to spec and found I pulled a full turn and a 1/2 more than what I had originally tightened. Haven't slipped since.
Whiff
Old Oct 16, 2006 | 01:52 AM
GeorgeJ's Avatar
GeorgeJ
No - I just used my euro torque wrench - "gooden tite". I'll crank up the snap-on to 60lbs and let you know. I would have never taken out the wrench for slip-on clamps. thanks. Great day riding up here on Long Island NY btw. These things run great in the cool weather!
Old Oct 16, 2006 | 10:54 AM
SDMF's Avatar
SDMF
Had my SEII's, at the time, installed at the stealership, and they drilled and riveted them together.
[IMG]local://upfiles/9114/2DB45054796140D1BA19C5A80C770B5C.jpg[/IMG]
Old Oct 16, 2006 | 10:57 AM
WdGldDave's Avatar
WdGldDave
Torque wrench + proper torque values + loctite (the red is really strong. If you think you will be changing the item from time to time, use the blue loctite. For heavy/big items, go with the red.) I've learned this the hard way.
Nascar89
2014-2024 Touring Models
18
Aug 6, 2014 10:24 PM
Mudslinger64
Mar 9, 2013 09:22 PM
LexiLee
Exhaust System Topics
May 22, 2011 06:45 AM
SciFiGuy
Aug 7, 2009 07:00 PM
GringoLoco
Jun 24, 2007 02:18 PM
