Changing front brake cables on FXDF
1: Do I need to drain the lines/calipers/master cylinder before unhooking the stock banjos from the calipers/MC?
2: Is there a best method of bleeding the system of air once I get the new stuff installed.
I appreciate any info you folks can give me. All the info that I've come across points to the process (especially bleeding) being a huge PITA, so I'm looking for some encouragement I guess. I'm sure I can handle it. I did already do the internal wiring extensions for my new bars, primary cover replacement, top and bottom rocker cover replacement, and turn signal relocation. Just fishing for a few helpful hints to make the job go smoothly. Thanks everyone!
You can disconnect the line at the calibers first and allow them to drain into a pan.
The master cylinder can be a bitch to bleed. A $40.00 manual vacuum pump is a great investment. I pissed away that much in brake fluid first time I tried to bleed mine without the pump.
When they start spurting fluid (have a plastic sheet over your paintwork unless using dot 5 fluid) then you bring the lines to the calipers (still holding them shut with fingers) and then (one at a time) slam the bolts in and tighten them onto the calipers. Pump like crazy with the bleed nipples shut until you get vague pressure, then finish bleeding as per normal procedures.
Works for me......
Harbor freight has a decent pump.
http://www.harborfreight.com/mityvac...ump-39522.html
or
http://www.harborfreight.com/brake-b...kit-92474.html
