Is there a an advantage to using a paint gun over a rattle can (provided you can get the colors correct)
And is there a guide for this process?
All I know as of now is:
1) Dissasemble
2) Degrease
3) Wet Sand down to bare metal
4) Primer Paint one layer
5) Sand Primer to coarse
6) Primer Paint one layer
7) Sand Primer to coarse
8) 2 Coats of Base Color
9) Sand to coarse
Than apply the Gloss to protect
I'm pretty sure thats no all correct, and a guide would be suberb.
you disassemble and wash the parts with something like dish soap...then you wipe it down with wax and grease remover(dont want to sand contaminates into the paint) if the paint is in good shape you just sand it with some 400 grit sand paper till all of the gloss is gone from the original surface. you re-wash the parts and then re wax and grease remove them.
then you use a tack rag to get all the dust off(really need a booth to spray in for best results) then you coat it with the paint youve bought and allow it to dry reassemble and enjoy!
My experience with rattle can is the paint can easily be damaged by spilling gas on it, at least it was for me, the paint would just bubble then peel right off, what a mess.Just my experience and maybe not others.
yeah ive been doing a lot of reading about it the last few days. Apparently so long as you use the correct clear coat it will hold up.
I will most likely end up powder coating it, unless I can get a stellar deal on a professional paint job.
Since I'm going with a flat color, powder coating actually works kinda well. Since from what I understand its major draw back is lack of gloss, and swirls in the paint (which don't happen on flat colors)
Heck maybe I should just Rhino Line the entire bike. Gotta have something to ride when the zombies come
