What are you using to mount them? How fun was that swap on the frontend? I did a fat front tire on mine. What spacer kit did you use and what front fender? Did it mate up okay or did you have to do any drilling? I found a FB front fender, but the lowers are completely different and had to drill new holes.
Vins,
the last 3 pics shows the mounts that I made up, they just bolt through the strut into the fenders captive nuts.
My fender/ strut captive nut set up has captive nuts for the both the front and rear bolts.
I moved my turn sigs away from that rear location to make it easier to fit my quick detach sissy bar that I made up also.
As for the frond end, Im running the standard 19" fender, wheel and forks.
I just bought the Black FatBob trees & axle and machined up spacers for the brake disc, axles and fender.
Just painted my fork lowers but will be powdering them soon as the front tire is nearly bald so may as well do it then.
