so is that all u do? use a scotchbrite pad to take it down to bare aluminum? couldn't u just use aerosol paint stripper for the same effect? and if thats the case do you put some clear coat or sealant over it so it dos not rust? thanks for the replies thus far by the way! always find this site helpful
As I understand, chrome plating is not susceptible of being 'stripped' with a chemical 'paint stripper' ... I just stripped some powdercoated parts (primary cover and cam cover) and scuffed up the aluminum parts with sandpaper ....
That gives them a similar appearance to chrome plating that has been scuffed up with scotchbrite ....
I have not tried scuffing up any of my chrome (intentionally) by using scotchbrite ... although I am contemplating it with my rocker boxes ....
A couple of other notes ... while you might be able to restore most of the luster to chrome (undo the scuffing) ... I don't think it would ever be 100% reversed ....
It is true that aluminum oxidizes and gives the surface a white powder appearance ... the ferrous content of steel oxidizes giving it a reddish appearance ("rust" colored) ....
R/
'Chop
Certainly not one you can buy over the counter. I was looking into buying a chroming business last year and the guy was giving me a walk-through. To strip the parts, they use muriatic acid.
this was one of my fav winter mods to my bike, i did my headlight ring, headlight visor, upper chrome shock covers, and tailllight and signals on my fxdb.
the scotchbrite took way too long, so i used 320 wet sandpaper ( dry) and a scuff wheel on my cordless drill. it worked great!! left some parts a little rough so i went back over them with a green scuff pad. one spot i burned past the chrome into the copper on the taillamp.. you MUST keep the same direction, or it will look like crap..
good luck on it!!
in hind sight.. i realize that the 320 grit paper cut the chrome really fast, but theres a few spots where i went too agressive and burned into the copper coat underneath.. only time will tell, wonder how it will age?? wanted to p/c them, but didn't feel like spending any $ on them...
a little WD40 with scotch bright works well on the shinney aluminum parts. I went over my fork slidders and triple trees with a clear coat, but it didn't hold very well. ended up scotch brighting it off and leaving it to oxidize, I kinda like the weathered look anyway. Now I'm in Arizona instad of the Pac NW so shouldn't oxidize much more.
