Throttle Adjustment
Old Apr 11, 2011 | 07:20 PM
RebelGlide's Avatar
RebelGlide
Default Throttle Adjustment
I put some new grips on my bike and the throttle now rocks rack and forth a bit like it has play in the linkage, i can't remember if it did it with the stock grips. It still snaps back to idle and seems to function. Has anyone ran into that? Do i just need to adjust it as the manual states? or should it have a bit of play in it?
Old Apr 11, 2011 | 07:55 PM
A1ACruiser's Avatar
A1ACruiser
http://youtu.be/QxglqX40-84
Old Apr 11, 2011 | 08:09 PM
jojo2dog's Avatar
jojo2dog
good vidio thanks
Old Apr 11, 2011 | 08:25 PM
A1ACruiser's Avatar
A1ACruiser
You are welcome! I believe the HD takes two 3/8" open end wrenches for the adjustment.
Old Apr 12, 2011 | 12:19 AM
cmvsm's Avatar
cmvsm
Yeah, just keep adjusting the idle cable nut until you get to that threshold where it started to stick and not snap back, but then one more turn of the nut gave it that quick release. That should be the sweet spot where you get as little play as possible.
Then of course with the throttle cable, you need to visually watch your adjustments at the carb until the throttle cam is a rats hair from touching the throttle stop.
You then should have reached the 'quan' and are good to go!
Old Apr 12, 2011 | 10:12 AM
stic2it's Avatar
stic2it
My problem is it works great, little to no play and then I turn the wheel all the way to the right and it goes back to sticking. I havent found an adjustment where there is no play and it doesn't stick with the wheel in all directions. If that makes any sense. On my bike there is always a small amout of play with the wheel straight, no play at all when the wheel is turned to the right or left.
Old Apr 13, 2011 | 12:24 AM
RebelGlide's Avatar
RebelGlide
same problem i just had trying to adjust mine
Old Apr 13, 2011 | 12:49 AM
blink1968's Avatar
blink1968
adjust it with your wheel turned to where it sticks
Old Apr 14, 2011 | 12:28 AM
RebelGlide's Avatar
RebelGlide
yup i do that then i get play when it is in the other postions
dlporter
Jul 28, 2015 10:02 PM
sajackson
Oct 11, 2011 09:21 PM
rpmarkley
Apr 22, 2009 11:05 PM
hd0wner
Jan 20, 2009 09:30 AM
bdavis
Apr 23, 2007 11:18 PM
