Im currently running a fat bob with Rush pipes 1.75 with a Vance and Hines fuel pak, K and N air filter.Bike is running good id like to add a SE Heavy Breather is anybody running this combo?Will she run lean with the added air flow of the HB.Im currently running the 0768 map.
Nah, I'd say you are good. Both the K&N and the Heavy Breather will easily flow enough for stage-1 and I wouldn't worry about the difference in tunes between them. Any slight change will be handled by the O2 sensors and ECU.
This is the same setup I run with a V&H 2-1 Big Radius and do not have any issues other than occasional popping on decel. I would have to research the map...but I run the one recommended for my pipes with baffels by V&H.
