Wheel Bearing Discussion
I should not say this, so knock on wood first, but I have never had a problem with wheel bearings and I do not worry about stuff that ain't happening just because I read it somewhere.
I have over 40k on my rears without an issue,
You have to remember that you have the double row wide bearing and the '08 up have the narrow single row set.
From a business side this does not make sense, he gets paid for the warranty work so why send easy money away and you take care of the customer as a dealer should?
The dealer has a responsibility to Moco, too. If some indy screwed up your bearings (how is the dealer to know he didn't?), should the dealer make a warranty claim to Moco?
From the business side, the dealer's ethics are spot on.
It was the indy's responsibility to replace the bearings. Didn't happen to have them on his shelf? So what? Most auto repair shops don't stock every part they replace. They usually order them delivered or picked up the same day. The indy could have done the same.
When I had my rear tire replaced, I had the indy order a set of bearings, along w/ the tire, tube and rim strip, just in case. Sure enough, the bearings were bad, and it was a simple, straightforward matter to do the whole thing at one time.
The dealer is blameless.
That is completely ludicrous and what you do with your bike is your decision and a questionable one at that!
The bearings were found faulty and that repair is covered under warranty, why should the customer have to pay for warranty work. It is completely legitimate for the Indy to put the vehicle back together and send it to the dealer for warranty repair, it may have been better to have it towed to the dealer.
Do you take you car to the dealer for tires?
This situation happens all the time in the auto-repair industry when warranty work is found during service. I have found many warranty repair items when performing many types of repairs and services and it is a professional ethic to forward warranty work to the dealer. It is the responsibility for the dealer to take care of warranty and it is the dealer who has to bear the burden of proof that there was negligence during the wheel R+R. Since the tire and wheel were installed and then taken to the dealer within hours, there is no legitimate argument to improper repair on the Independent service shop's end.
On top of this, the bearing failures on '08 up, especially the rears, are a common problem, lending even more credence to part failure unrelated to a previous repair.
The Dealer, in this case, is completely Unethical and so is your position!
7500 miles and one of the HD 9276 bearings would hardly turn and the other side was smooth.
Did the work myself using first a slotted 25mm expansion tool to knock the bearings out with a wack of the long shallow ground chissel. "out of there".
kept the spacers on the correct side, cleaned and coated everything with never-seeze. Used the axell socket to install the new bearings.
Installed the new bearings rotor side bottomed first then the spacer then drive the bearing to meet the spacer.
Put it all back together including the new brake pads and cleaning of the calpier pistons. didn't pop them out all the way just enough to clean,shot of cleaner lube and new brakes tightend to 100 LBS using a torque wrench and feels good.
I take it out tomorrow.
Bearings were less than $17.50 delivered. ebay
peace of mind.
The bike is still under warranty but I have this thing of doing it myself anyway.
While away on vacation had the tire mounted and balanced by local so I returned today and got it done for tomorrow. No trip to the dealer, no down time.
Better bearings anyway.
