Metzeler 880's on laced wheels?
I went and got the tires and wheels and put them on the bike, but then started seeing some posts here that said using radial tires with tubes is not good, and some other stuff regarding radials on the rear. Even read about a guy with a death wobble from the rear at 70-80 mph! I'm not a tire expert.
so... experiences? opinions? advice?
The dealer was the only place that was weird about mounting tires for me, hut them went on to tell me the stock replacement dunlops were the only good option
I have an 07 SB with spokes and am on my second set of 88o's...absolutley LOVE 'EM!! Made such a difference in handling from the Dunlops I couldn't believe it.
Just have to ensure recommended tire pressures are maintained - they are slightly higher than what the Dunlops run....
My buddy runs the Avon Venoms on his chopper on laced wheels and he loves them also.
Adding to the confusion is that neither tire is stock for the lowrider, so looking up numbers on the Metzler website doesn't help. I have a front wheel from a heritage and the tire is a MT90B-R16. The rear I decided to go with a 170/60R17, instead of the stock 160 width. The rear does say "tubeless" on the sidewall, but I don't think that means it can't be used with a tube. I would also hope the people at the indy would know better if I was trying to do something that wasn't safe.
Looks like if everything is inflated, adjusted, and aligned properly I won't have any problems.
One more question. Do radials require a special tube? My front has a stock HD tube, but I had the indy put a heavy duty tube in the rear.
Thanks
Well, the little light flickered and finally went on. I have a bias ply on the front, and a radial on the rear.
If it will be an issue I will talk to the indy and see about getting a bias for the rear.
Anyone think the rear radial will be a problem with a tube?
Thanks
