Adjusting shocks-they keep turning
Old Apr 28, 2011 | 06:31 PM
MDStbob's Avatar
MDStbob
Default Adjusting shocks-they keep turning
probably a stupid question but I cannot find an answer. I am trying to stiffen them up and I am turning them the correct way (clockwise) but they keep turning. I thought they stopped when they are at the stiffest setting? Please help bike will be loaded for a four day trip and I have to get this done ASAP.
Jim
Old Apr 28, 2011 | 06:50 PM
O-Town D's Avatar
O-Town D
Sounds like you've gone way past the max preload setting. You need to turn the adjuster all the way back (counterclockwise) until it stops, which is position #1 (lowest preload). Then turn the adjuster clockwise 1 step at a time until your preferred preload is reached - position #5 is max (only 4 clicks beyond position #1). Be sure to use the same setting on both sides. Hope that helps.
Old Apr 28, 2011 | 06:51 PM
JaronB's Avatar
JaronB
They do not stop at the stiffest setting, they just drop right back down to one. You'll have to look on the under side and count how many spots to move up and double check it when you're done. Then you're good to go. I'm assuming you are using a spanner wrench on the bottom of the shock where the little holes are?? Not spinning the spring right??
Old Apr 28, 2011 | 07:22 PM
MDStbob's Avatar
MDStbob
yes using spanner. and thanks I knew it would be easy
Jim
Old Apr 28, 2011 | 10:10 PM
JaronB's Avatar
JaronB
Cool! Have fun on your trip!!
hemi1300
Jul 21, 2018 09:21 AM
noridinsavage
Electrical/Lighting/Alarm
Apr 26, 2012 01:20 AM
larazauk
Apr 23, 2009 03:29 PM
Streetrunner
Aug 13, 2008 11:32 AM
clenaghen
Jun 1, 2007 09:43 PM
