Question for True-Track owners
Old Aug 12, 2008 | 10:03 PM
Streetrunner's Avatar
Streetrunner
Default Question for True-Track owners
Just installed a True Track stabilizer and I'm not sure the stabilizer link is in the neutral position.
I am not able to turn the adjusting nut by hand, I have to use a open end wrench. I turned it one way till it felt tight then back in the opposite direction till it got tight (about 1 turn) then turned it back to the halfway point where it moved a little easier. My concern is that the directions lead me to believe that it should move freely by hand.
I'm hoping I am not putting any undo side to side stress on the trans etc.
Can I hear from those that have performed this install? Is all ok or do I have a problem?
Old Aug 12, 2008 | 10:29 PM
whoop72's Avatar
whoop72
I don't recall if the nut turn hard or easy, but it sounds like you've done it correctly; hitting the middle sweet spot.
Old Aug 12, 2008 | 10:37 PM
JustLoafin's Avatar
JustLoafin
When talking to the True-Trak crew at Sturgis about this very thing they said that you want to find that middle sweet spot to keep the setup in a neutral state. If you are trying to compensate for bad alignment you need to fix that first then install the True-Trak. If you have no alignment problems then you are doing it correctly. Just remember to do the install on a bike jack or platform and not on the jiffy stand.
Old Aug 13, 2008 | 07:16 AM
papifun's Avatar
papifun
what is differance of the True-Track vs the Rev-Tech version? Is one better than the other ?
Old Aug 13, 2008 | 09:37 AM
rideon's Avatar
rideon
Yes, you did the job correctly. I did mine the same way, works perfectly.
Old Aug 13, 2008 | 09:44 AM
sanaga's Avatar
sanaga
sorry..but where i can buy this true track...?
my bike wobble like hell at 100 mph......
Old Aug 13, 2008 | 10:08 AM
Streetrunner
I installed it with the bike on the jiffy stand. I believe the directions stated that was ok.
Where did you hear that it should be sitting upright?
Old Aug 13, 2008 | 11:32 AM
whoop72's Avatar
whoop72
true-track.com
Northbound Southerner
Oct 16, 2015 08:12 AM
PiedPiper
Shovelhead
19
Mar 10, 2013 03:00 PM
noridinsavage
Electrical/Lighting/Alarm
Apr 26, 2012 01:20 AM
MDStbob
Apr 28, 2011 10:10 PM
kully
Apr 6, 2008 06:56 AM
