Another Exhaust Leak Question
Old May 2, 2011 | 12:39 PM
lennyb3us's Avatar
lennyb3us
Default Another Exhaust Leak Question
I just installed V&H BigShot staggered on my 2000 lowrider. They sound great but occasionally on heavy accel it will pop on decel. It seems fine on light to mmoderate acceleration, no pop. Could this be an exhaust leak? I thought if it were an exhaust leak it would due it more consistently. I did by the way change out the gaskets. I used a new set of the stock gaskets. I have the se flat ones if it turns out to be a leak, but would rather not if I don't have to. . While checking things out. I leaned it out a bit by pulling the enricher out and it seemd to not dO IT.ANY HELP WOULD BE GREATLY APPRECIATED
Old May 2, 2011 | 12:43 PM
nevil's Avatar
nevil
It could be an exhaust leak but it could also be that you need some tuning since you just put on a new exhaust system.
Old May 2, 2011 | 01:56 PM
8541hog's Avatar
8541hog
Now that the bike has heated up and cooled, check the torque on the exhaust flange nuts, make sure they are tight.
When you pulled the choke you were actually making it richer, not leaner.
Anytime you go from heavy accel to decel quickly, especially if you don't let off the throttle all the way you may get some popping. Next time trying closing the throttle 100% and see if it still pops.
Old May 2, 2011 | 02:42 PM
lennyb3us's Avatar
lennyb3us
So if it is just a slight/intermittent pop on decel is there any harm to the bike?
Old May 2, 2011 | 02:53 PM
8541hog's Avatar
8541hog
Without actually hearing it can't say for sure, but if it is slight, and not all the time, most likely not harmful.
Old May 2, 2011 | 02:54 PM
Los11's Avatar
Los11
Not at all I had a slight decel on my 100 S&S motor running short dual pipes like your V&H and it really depends if you just want to get it tuned out I do all my work but for that I took it to a carb genius and he tuned it out for me cause it just bothered me although at night the flames on the decel pop looked cool.. Remember when you get decel pop your running rich its to much fuel so like ^^ was said try leaning her out some more if it bothers you that much have it tuned out you may need to go to a bigger or smaller jet I am not sure what your running... Good luck bro
Old May 2, 2011 | 03:32 PM
lennyb3us's Avatar
lennyb3us
I'll put some new plugs in it and tune it tonight and post the results thanks for all the input.
Old May 2, 2011 | 03:44 PM
kk6pg's Avatar
kk6pg
You might want to try turning your mixture screw in a quarter turn
brad75raiders
EVO
May 26, 2018 01:06 AM
MNtadpole
Exhaust System Topics
May 3, 2015 08:30 AM
Ricketts
Oct 16, 2014 10:32 PM
Tucker99
Jul 7, 2014 02:05 PM
paulydg
Jul 29, 2008 01:04 AM
