Axle Question
Old May 6, 2011 | 07:11 AM
Fastfwd's Avatar
Fastfwd
Default Axle Question
Forgive me, no, I don’t have the service manual – just would like a bit of reassurance.
Got 27,500 miles on the Bob and replaced my bearings with some Japanese bearings before the replacements that went out at 15k do the same thing.
My question is now that I’ve seen what all is inside the wheel – help me be clear on something. The grease on the axle from the factory – is that mostly there to keep it from seizing up and being difficult to get in and out?
I mean, the inner part of the bearings and that removable inner shaft basically stay stationary on the axle and the outer part of the bearing spins with the wheel, right? All of the ‘spinning’ is done by the bearings themselves?
I only ask because the axle seemed like it was a bit on the dry side, but that’s how it has always seemed to be when I pull them. None of the spinning is dependent on that grease right?
Old May 6, 2011 | 07:28 AM
flynavy's Avatar
flynavy
Fastfwd - you have nothing to worry about!!
I just removed and replaced the front wheel on my Bob...the grease on the axle is anti-seize and meant only for ease of install/removal.
You are correct on the operation. The axle doesn't move.
If it was a bit dry, the worst you will experience is the axle being tough to remove the next time you need to do it.
Really if you spread around what was already there with your finger, it should be ok.
Keep the shiny side up!!
Old May 6, 2011 | 10:49 AM
JRK5892's Avatar
JRK5892
it is anti seize you should use it when you put it back in... makes it soe they come out again!
scooper321
Wheels/Tires
Feb 23, 2018 06:03 PM
dugan
General Topics/Tech Tips
17
Jan 18, 2018 04:33 PM
Hawkeye69
May 14, 2015 09:28 PM
Pinetop
EVO
Feb 6, 2013 12:06 PM
HRK123
Aug 4, 2012 01:35 PM
