LED Replacements for 1157's?
Old May 15, 2011 | 12:50 AM
cjlandry's Avatar
cjlandry
Regarding load equalizers, those are a bummer. My primary reason for wanting LED's is to reduce the load on the alternator while riding.
If it works with the LED's on the rear, and standard incandescent 1157's up front, I guess I'm halfway there.
Also, the "load equalizers" are nothing more than resistors. Radio Shack has those, plenty cheap. Just get sufficient wattage resistors and install them in series with the LED's if you need them. Sadly, though, load equalizing resistors will bring the load back up to the same level as the incandescent lamps.
If I need them, I may experiment with lower resistance values, just to decrease the load as much as possible without causing the signal circuit to behave as though there is a burned-out lamp.
Old May 15, 2011 | 02:04 AM
abadv8's Avatar
abadv8
I have to chime in here...
Load equalizers are in parallel, and increasing resistance decreases the load.
P=IV & V=IR
Old May 15, 2011 | 04:55 AM
RICHIEMACK's Avatar
RICHIEMACK
Remember to get 1157 and 1156 for back .i had the red led from ebay ,they look great
Old May 15, 2011 | 05:08 AM
masterblaster's Avatar
masterblaster
Do you have to splice the equalizers or do they plug in somewhere?
Old May 15, 2011 | 07:30 AM
drnk_n_publick's Avatar
drnk_n_publick
Originally Posted by fenderzig
I'm running these.
http://www.amazon.com/gp/product/B000TK3TPO
direct fit and no load equalizer needed.
How much brighter are these than the stockers? I'll probably grab a set.
Old May 15, 2011 | 07:31 AM
cjlandry's Avatar
cjlandry
P=IV & V=IR
Thanks. I knew that, but wasn't thinking.
1157 on both ends for mine. The turn signals are also the tail-lights. There is no middle light on the '11 Wide Glide.
Old May 15, 2011 | 07:39 AM
cjlandry's Avatar
cjlandry
This one is supposed to plug in, I guess, but it doesn't specify which bike.
http://www.amazon.com/Universal-Harl.../dp/B002VESBFO
I learned that the WG plugs are different from other models when I installed the license plate/signal relocation kit. Not a big problem for me, only a slight nuisance.
Old May 15, 2011 | 11:03 AM
abadv8's Avatar
abadv8
I keep looking at the optoelectronics section of DigiKey and wanting to build my own inserts...
Let's see, 40-50 leds per insert, $.03-.06 each. I'm sure the higher output versions are exponentially more expensive.
I do like the custom dynamics inserts...
Old May 15, 2011 | 12:38 PM
fenderzig's Avatar
fenderzig
I just went out and snapped a few pics for you. The bike is sitting in my garage and door is wide open so the garage is pretty bright right now. This is without a flash on the camera. I tried to capture the LEDs and represent them well. They are brighter than the stockers.
First pic is the running lights:
Second pic is after applying the brake:
Old May 15, 2011 | 02:58 PM
Sonic_Excess's Avatar
Sonic_Excess
You could always give it a shot with leds in both without the equalizer. I ran the autozone led lights in the rear with no front signals and every thing worked fine, all that happens is the turns blink a little faster. I have since put the front turns back on and am planning to do the same thing myself.
