streetbob tank removal
Old Oct 27, 2006 | 07:33 PM
1ironhead's Avatar
1ironhead
Default streetbob tank removal
Has anyone removed their bob's tank?If so how.
I ask 'cause it looks a little different from my old ironhead,
what with the fuel injection and all.
Thanks in advance,
Bob
Old Oct 27, 2006 | 07:41 PM
kpreese's Avatar
kpreese
Default RE: streetbob tank removal
The service manual describes it pretty well and I don't have mine handy but I'll wing it.
The manual tells you to pull the fuse for the fuel pump and crank it a bit (perhaps run until it dies) then it is safe to remove the fuel connector. That just depressurizes that line. If I remember right, it is a quick disconnect type of thing where you push up or pull down on the sleeve and it releases easily.
Then obviously you'll need to take the dash off and get whatever wires out of the way. The crossover tube will also need to be removed and the tank drained which sucks.
Kevin
Old Oct 27, 2006 | 07:54 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
A service manual is a wise investment if you plan to do your own work
Old Oct 27, 2006 | 07:59 PM
1ironhead's Avatar
1ironhead
Thanks.The bike's in a storage unit along with the
manual(somewhere) and all my stuff.The tank got
sugared last week end,so I'll have to skip the start
up part.
Bob
Old Oct 27, 2006 | 10:44 PM
mikeurig's Avatar
mikeurig
So now you need a gas cap lock?
Old Oct 27, 2006 | 11:13 PM
gbm's Avatar
gbm
Bummer. Hope the fuel pump isn't hurt.
Old Sep 30, 2007 | 02:23 PM
terminatormike's Avatar
terminatormike
question.
has anybody the partnumbers of:
streetbob 2007
-gas tank
-fuel pump
thanks terminatormike
Old Sep 30, 2007 | 03:02 PM
js1268's Avatar
js1268
change the fuel crossover line, too..... get the chrome braided one after you ruin the stock one that came with it
Old Sep 30, 2007 | 03:46 PM
SFD_207's Avatar
SFD_207
ORIGINAL: js1268
Yeah ... The stock fuel lineDOES break EASY too ......
Old Sep 30, 2007 | 06:08 PM
sintax's Avatar
sintax
ORIGINAL: 1ironhead
up part.
Bob
WOAH! Someone put sugar in your gas tank? [sm=WTFsgign.gif]
Is this a somewhat common thing? That is horrible!
