Decel popping
Old May 24, 2011 | 10:39 AM
Krazy8s's Avatar
Krazy8s
Default Decel popping
with stock Intake, Pipes and ECM...
Bike used to do it occaisionally, now it does it every time i back off the gas.
Not thinking that it is damaging the bike, just curious as to why it has suddenly started. (and if it is somehow damaging the bike then i'd like to know).
Just shy of 7K miles on the bike.
Thoughts?
Old May 24, 2011 | 10:49 AM
Squirrel67's Avatar
Squirrel67
Check the torque on the pipe flange bolts at the heads.
Old May 24, 2011 | 10:58 AM
paulies 07's Avatar
paulies 07
These bikes run very lean, I just pulled the trigger and bought Fuel Moto's brand power
commander, 239.00 plus shipping, and what a difference, had xied's, they worked ok,
but still had a lot of popping, and my scoot ran very hot.
Fuel Moto (Jamie) really hooked me up, no more popping, no more extreme heat, and
much more power, wish I'd done it sooner, plus any changes you make to your scoot
you can remap your self, easy to do, did I say I have more power? visit there web site
you can spend more money on one of these wigets, but why? www.fuelmoto.com
ord sgt's Avatar
ord sgt
Be sure to twist the throttle completely off between shifts. Anything else dumps fuel thru the system, creating the backfire.
Old May 24, 2011 | 11:07 AM
Krazy8s's Avatar
Krazy8s
Saving my pennies for a PCIII as we speak, not quite there yet. 2 more paychecks then i'm in
as for the popping, it just seems a bit odd that it went from occaisonally to all the time almost overnight. Gonna check head pipe torques and pipe joins tonight just to see if something has loosened up a bit.
Old May 24, 2011 | 11:40 AM
8541hog's Avatar
8541hog
+1 on this.
It really does make a difference, next time you are out, cruising down a slight hill, let of the throttle partially and listen, then do it again and roll the throttle off all the way and see if there is a difference.
As suggested, check your exhaust manifold nuts too.
Old May 24, 2011 | 09:27 PM
bigdaddy33's Avatar
bigdaddy33
+1 That's what I would check first.
LCCXL1200X
Jun 23, 2020 01:11 PM
kcollins
Mar 14, 2017 01:38 PM
fat daddy
Apr 7, 2012 05:28 PM
achog88
Nov 30, 2009 01:37 PM
srigas
11
Aug 12, 2006 02:46 PM
