No problems with my 02 WG, other than a few common wear & tear type things - my stator went out around 35,000 miles, and a loose battery cable recently (dealer's fault - they stripped the screw when they did the stator - and left it that way).
Do you think the WG would be ok (comfort-wise) for one rider for a 1300 mile trip?
Haha. I just rode 1500 miles two weekends ago. Left Thursday after work, and got back Monday early afternoon. Spent 2 hours visiting my Dad and turned around. Calgary, AB to Vancouver Island, so a large part was through the mountains. No sore anything (back, shoulders, butt, legs). But for the longer rides (over 3 hours), I do put my windshield on.
Just took my cousin out for a couple of hours last weekend, and didn't even really notice her on the back (no noticeable power decrease, handling issues, etc).
FXDWG sounds like a good choice for you. You'll really like the handling. If you are into twisties, then you'll get used to (and look forward to) dragging your heels in the tight ones. They don't turn like sport bikes, but I understand they turn much better than the soft tails.
Wolvie give horse back riding a try. I use to do riding therapy with children with spinal problems and the motion of the horse moving helps reduce pain. It really works. As for the bike it also helps, you get more benefits from using the horse.
I have back problems too a found that riding the bike helps.
Sure glad my wife didn't see this post, she's been trying to get me back on a horse for the last three years! She is persistent so I'll have to give in sooner or later.
Originally Posted by PKellyMc
My biggest problem is running out'a gas....seems to happen every 200+ miles...costin' me a fortune in repairs !
2004 XL1200C - second owner - all servicing done on schedule.
Rear master cylinder and all brake pads replaced at 10000 miles.
Clutch rivets blew at 20000 miles - had to replace the clutch pack plus took out the clutch shell, bearing and gaskets (ttl $950).
This is my daily driver and I guess I'm not all that happy. I could have spent that money on trading up instead of treading water.
18 months and 14000 miles later - clutch failed again. Dealer says he'll fix it for nothing but they don't have parts. What are the odds I'll have it back before Thanksgiving? Not very good.
Is it possible that a PO did a primary sprocket mod on your bike? If so, you may be unknowingly slipping the clutch, etc, due to the higher overall gear ratio. I have an XR, and it is a popular mod on their forum, but I like the stock lower gearing. May want to ask the dealer to check for stock sprockets in the primary while they have it open... Just a thought. Harley clutches are not known to be a problem... dd50
