Fat Bob for a beginner?
http://www.debrix.com/Heel-Toe-Shift...21-0681-vt.htm
The forwards were a must for me. Wouldn't mind if they were a couple inches further out. I have a stock Street Bob seat and end up riding at the back/top of the seat a lot to get the distance to stretch out. I've put about 1200 miles in and have pretty much gotten used to where the shift/brake pedals are.
On the mids - I wanted them too. Actually have looked for mini floorboards that flip up. Now I'm re-thinking it. If I want a new spot, I use the existing passenger pegs. Also works well in the winter to help keep my legs a little warmer.
I have a windshield - bought the bike used and it came with it. Haven't used it since the weather has improved, but have found it pretty helpful in cold weather.
Give yourself some time on the bike before you do much to it. You might be OK with things you think yo want to change ... and it'll save you a ton. I'm learning pretty fast that nothing that has to do with a Harley is inexpensive!
You might want to check out the Rush slip-ons for a less costly exhaust option that sounds good. And check out the http://www.badgcustoms.net/solo-bags.html solobags. I'm about to order a set. Search here. People have said great things about them.
Last edited by voudoujoe; Jun 4, 2011 at 10:26 PM. Reason: added stuff about pipes and bags
But, if you prefer the Heritage don't buy the Fat Bob because the Bob is cheaper. MSRP on the black Heritage is $16,999. The Fat Bob is $14,999. That only two grand. Plus, you said you want bags (which will probably run you $800 or so from the dealer) and maybe a windshield (another $400 or so). You're within a thousand bucks of the Heritage then.
Seems like a no brainer to me. If need be, save up the cash difference before you go in to finance.
For the exhaust sound, a pair of slip-on mufflers will get you there. I picked up a pair of Rush slip-on mufflers from a member here for a very reasonable price. With the two-inch baffles, it definitely rumbles.
For a beginner, no worries. Just take your time and take a rider's course. Read as much as you can, and watch videos. Learn low speed control and some emergency maneuvers. It's not so important which bike you learn on, just learn and always bear in mind that you'll never know all there is to know about riding. Safety is more important than impressing yourself with your cool skills at scraping the pipes around turns.
It's a beautiful bike. I hope you get it and enjoy it as much as I enjoy my new Wide Glide.
I do recommend that you get a tuner as soon as you can. The factory tune is very lean, and that translates to heat. A good aftermarket tuner will fatten up the mixture enough to cool things down and keep your right leg from turning into barbecue. The heat shields can only do so much.
I wonder if id have any luck finding a 2-3 year owned pre-owned which would be basically same price that id be paying for FB
I was just worried because im not stocked up with many tools, or have much time to be working on it so i didn't want to inherit someone else's problems. But i guess it cant be too bad if i don't go too old, right? lol
