Dyna to Softail conversion?
the suspension/frame is completely different.
you;d have to pull the engine from a dyna and throw it in a soft tail frame, which had its own version of the dyna engine invented just for the frame.
what you're asking makes no sense at alll.
And it would appear he's a new member (and if all the "love" continues, probably not a long term member) he may not be familiar with some of the nuances between the two models.
If you do want to make a big change on your Dyna, have a similar visual effect, but with even added cool, check out Heartland or www.heartlandbiker.com Their new Dyna fat tire kit will definitely give you a bigger cool factor, less headache and a smaller cash outlay.
Before you are done, expect to pay $5k or so, but you will be $$ and sense ahead of having a customized and bastardized, untested prototype of an inferior design.
Another, even cheaper way to get a softail, is to shop around and buy one. You might pick one up for the same price that you can sell yours for. This would cost you nothing, the savings would be over $5k.
The benefit won't weigh well against the cost though. You'd be better off getting a softail std...same look.
It'd cost big $$$ to make a softail look like a fat bob
