Xied's??
Old Jun 8, 2011 | 07:59 AM
The Dean's Avatar
The Dean
I run the XIEDS and after 5k the plugs are as clean as new. Good gas milage, cooler, and easy to install. It is a good fix. If you do much more then AC and slipons you might need to install a tuner.
Old Jun 8, 2011 | 09:02 AM
grog_lives's Avatar
grog_lives
If I understand correctly, xied's are pretty plug and go? So essentially there should be no tuning required?
Old Jun 8, 2011 | 09:05 AM
black1125's Avatar
black1125
A tuner is a waste of $$ if all your doing is air filter and pipes, xied's will work just fine on a "stock" bike, and plan to keep it that way..
Old Jun 8, 2011 | 11:12 AM
grog_lives's Avatar
grog_lives
Side question, if one changes the pipes and AC, that's still considered stock?
Old Jun 8, 2011 | 11:33 AM
traveler's Avatar
traveler
XIED'S will work with pipes and air cleaner change.
My personal MPG was unaffected. My personal MPG is 43 overall. Once went to mid to high 30's but that was because I was going into a 30-40 MPH head wind, which is understandable...pushing the fairing, etc. through the wind.
Oil temps NEVER go above 230, and generally stay around 205-210.
Plug and play at it's finest!
Steve at www.nightrider.com
Give him a call, VERY nice guy.
I HIGHLY recommend these.
~Joe
Old Jun 8, 2011 | 12:41 PM
Gay Rider's Avatar
Gay Rider
I believe Harley Davidson refers to it as Stage 1.
Old Jun 8, 2011 | 03:47 PM
grog_lives's Avatar
grog_lives
~Joe
I called Steve and he indicated a 25 degree nominal temp drop. I'm guessing this can very, but will I sense a temp drop on my thighs. I ask this because I recently put slip-ons on and the cycle now feels hotter than with the stock, and I could feel plenty of warmth then.
Old Jun 12, 2011 | 10:16 PM
grog_lives's Avatar
grog_lives
For those who have put a new exaust and AC and went with the xied's, what did you notice with performance gain?
Old Jun 12, 2011 | 10:22 PM
Frank ZX's Avatar
Frank ZX
I just installed the night rider IXED on my 06 WG and rode it to work tonight. It does seem to have more power and run cleaner but my CEL comes on at idle. I was told by a very kowledgable tuner our bikes run in closed loop so the IXED were fine for a aircleaner and exhaust upgrade.
Old Jun 13, 2011 | 12:10 AM
dfndr's Avatar
dfndr
Works fine on my 2010 Heritage with no costly or hit and miss dynotune.
