Tire pressures?
Old schoolers have been telling me to fill to the max rating on the tire +/- 2 lbs.
DougJ
In years past I had a BMW and went with the owners manual recomendation. The rear tire needed replacement at 6500 miles. I asked the dealer about this, and he had me increase
my rear tire pressure by 8 lbs. and front by 6 lbs. I then almost doubled my tire mileage.
I run 40 rear and 36 front on my Dyna.
hdrider02
Kieth:
hdrider02
Take the advice of 40 rear/ 36 front.............. It is too late, now to get much more than 6 or 7k miles out of the rear safely, now.
I know, because I ran my HD Dunlop rear at the solo recommended psi of 36 psi, and the rear was bald at 6500.
It appears you ride ride a lot like the rest of us (maybe a little more conservative).
I am not trying to push the Metzeler tire, but I ride routinely over 80 mph, and a lot over 100 mph (don't judge me), and my Metzeler ME880 has over 4,000 miles on it and looks almost new.
IMO, if someone gets 12-14k miles with a stock HD Dunlop they must be pushing the bike around town. LOL
I never expect anyone to believe my BS, but Metzeler's own recommendations for my particular ME880 is:
rear solo=44-46 psi, 2up light=46-48 psi, and 2up heavy=48-50 psi.
The ME880 Bias ply has a max pressure rating of 50 psi (COLD). Has a load rating of 963 ilbs., and a max speed rating of 149 mph (which I haven't been able to observe myself doing).
ttp://www.us.metzelermoto.com/media/m_06_vtwin.pdf
The stock Dunlop tire that came on our Dynas is a K591 series 160/70B17 73V with a max pressure rating of 42 psi (COLD), load rating of 805 lbs, and a max speed rating of 149 mph.
http://www.dunlopmotorcycle.com/info...tirecharts.asp
The reason I understand that we don't measure tire pressure when a tire is warmed up (not necessary HOT), has alot to do with the mixture of water molecules, etc. with the air itself, resulting in erroneous readings. In fact, sometimes a "hot tire" will actually read lower than it actually is, not higher.
By running too low a pressure in the tire, it runs too hot, ruining it from the inside out.
Also, motorcycle tires are not "flat buttomed" like automotive tires. They are rounded with a much smaller contact surface when going straight, allowing the bike to roll sideways to make turns (ever lean your car to go around corners?).
Sorry for the rant, hope the info helps.
DougJ
