WIDE TIRE KIT QUESTION
Old Nov 5, 2006 | 10:47 PM
PowerCobra98's Avatar
PowerCobra98
Default RE: WIDE TIRE KIT QUESTION
Thanks. I don't see why the current plates I have under the fender won't work after seeing these. I don't think the kit is necessary.
Old Nov 5, 2006 | 11:50 PM
misfit's Avatar
misfit
I'm with veniculum. I too have the 180 kit installed and the SE tire is great. I've got over 5K on the tire and no problems wet or dry. Try it out if you don't like it for some reason change it out.
Old Nov 6, 2006 | 12:04 AM
Hogpro's Avatar
Hogpro
Former Sponsor
A 200 eill go on a Wide Glide with no mods. (Bobtail fender). On all other models the rear turn signals must be removed to make room under the fender. We replace the rear light with a Kuryakin with built in turns.
Jerry @ Hogpro
Old Nov 6, 2006 | 12:51 AM
clayman's Avatar
clayman
Thanks hogpro. i was checking out your site you guys have some nice stuff, i am wanting to get some new rims and tires for my 06 fxdbi. Only problem for me is that i take a beating getting stuff sent up here to canada.
Old Nov 6, 2006 | 01:50 AM
Hogpro's Avatar
Hogpro
Former Sponsor
One of our Canadian customers always has us send his stuff expedited UPS. Hey says that avoids a customs charge.
Thanks,
Jerry
Old Nov 6, 2006 | 02:42 AM
wlbowers's Avatar
wlbowers
Ya Don't Need The Kit
I have an 06 Low Rider.
The kit has the tire, 2 fender support bars and a few ty-raps.
The bars in the kit are the same as the ones that you use to relocate the turn signals. Or put on the saddle bags. I have two extra sets I'll give someone if they pay the postage.
The only thing ya have to do is cut the bolts off flush with the bars and make sure the TS wires are out of the way.
When I relocated my turn signals, the bars I pulled out looked the same as the ones I put back in.
I bought the 180 Dunlop and had the dealer put it in. He cut the bolts off and I have loved it ever since.
Old Nov 6, 2006 | 03:18 AM
clayman's Avatar
clayman
Thanks for the info Jerry i will look into that.
Old Nov 6, 2006 | 08:23 AM
06dynablack's Avatar
06dynablack
wlbowers so your saying the 2 nuts that at the very rear of the brs on inside of fender?couldnt very well cut the nuts off far as i see.not sure what size they are guessing half inch or 9 sixteenths they are.i have no bolt extending on outside of the nut.so i must be good to go
Old Nov 6, 2006 | 10:44 AM
jt1965's Avatar
jt1965
I have the 180 tire mounted on my Bike. I just ordered the tire from Zanottis and had an Indy put it on for me. No problems and it rides great.
Now If it would just stop raining.
Old Nov 6, 2006 | 04:12 PM
Alaska Bobber's Avatar
Alaska Bobber
I always wondered what this "wide tire" kit was to fit a 180. Mine came with a 180. I thought I was special, turns out I'm not and you don't need that dumb kit.
Think a 200 will fit if we move the turn signals up to behind the seat?
