Batwing fairing, revisited
anyone? pros, cons of using a HD unit?
the bags are now in primer and blocked out ready for paint, have to touch up the block sanding on fairing... paint is on the way so i can shoot it... going to use PPG DCC acrylic single stage gloss black to shoot the bags and fairing...
made new hinges for the saddle bags and welded them up ready to be coated... all the hard ware and some metal bag wraps and fairing wraps will be coated in the blue to match the bike... have not had much time to get on it due to how busy the shop is... but have to have it done by the 15th for a 11 hour ride we have coming... so expect serious updates shortly!
https://www.hdforums.com/forum/dyna-...airing-in.html
all in all you pictures look like what I want to do, here is what i am starting with
Or WHERE To Get the Fairings, what is it called even (part #)?
I also am looking for a Cheap Fairing option for my 07 dyna.
Can I get a Fairing with stereo & speakers for 500-600 buks?
http://dragulacycle.com/components/c...fe3a0281a5.jpg
350.00 plus shipping road king
Dyna Sportster fairing
http://dragulacycle.com/components/c...0063717ca9.jpg
399 plus shipping
the Tsukayu fairing is about 750.00 minus stereo
wide open customs is 850.00 with stereo
i happen to be cheap so I am still looking for a lower dollar option, although the dragulacycle unit is probably the one I will go with
or does someone make and sell the brackets?
Thank you for all the links and names!
the Tsukayu faring is about the most complete I have seen, although the Dragula Cycles fairing is pretty complete in its list as far as fitting with their brackets, it sounds like a complete bolt on, the wide open customs fairing (I looked at these in Daytona) are not quitck release, so looking at it I knew I would have to fab up some brackets to make it a quick release anyway
here is yet another option for the road king fairing, this one looks pretty good on the fit and finish
http://www.theusatrailerstore.com/st...cycle-fairing/
its 350 plus shipping but once again brackets to fit a dyna will need to be fabbed and adjusted
reckless motorcycles, makes fairings as well, not dyna specific but none the less makes some, again with some brackets fabbed p, it looks like it will fit, in joes thread above he uses a reckess fairing
