Big sucker 1 TROUBLE, please help!
Old Jun 24, 2011 | 12:45 AM
128auto's Avatar
128auto
Default Big sucker 1 TROUBLE, please help!
Installed my BS1 this evening, everything went well, when I tried to put the air filter on, it doesn't fit. The holes offset on the air filter doesn't match the base 3 mounting bolts. I also found the air filter sits a bit higher, it looks a bit taller than it supposed to be, won't even touch the mounting bolts. Can you BS1 ppl do me a fav, measure the height of your air filter, I mean the thickness from the bottom to the top and tell me what it is, so I can talk to fuelmoto tomorrow. I don't think the BS housing is wrong, it fits right on the throttle body, it could be air filter boxed wrong. Thanks!
Old Jun 24, 2011 | 01:18 AM
Foxster's Avatar
Foxster
Old Jun 24, 2011 | 01:46 AM
HemiOrange's Avatar
HemiOrange
Don't know what you are talking about. I can't see how my Arlen Ness Big Sucker, with it's installation instructions, could be confusing.
Do your parts coincide with the part list? Did you read the instructions? Did you buy it used?
I've since replaced the BS filter with a Wimmer, so can't measure whatever measurement it is that you are asking for.
Old Jun 24, 2011 | 06:05 AM
8541hog's Avatar
8541hog
How far off are the holes? Mine were slightly off and with a little persuasion it bolted up. There should be a small gap between the bosses for the screws and the filter, so we need to know just how much we are talking about.
Old Jun 24, 2011 | 07:08 AM
128auto's Avatar
128auto
At least 3/8, I mean I cannot even line up 2 holes at a time, the 3 holes offset is totally off no kidding. I can take pictures but you can't tell until you put it on. The air filter metal face plate to the bosses gap is also 3/8, that's why I thought the filter is box wrong.
Old Jun 24, 2011 | 07:17 AM
8541hog's Avatar
8541hog
How deep is your filter? Is it a true Ness unit? A picture would be helpful
Old Jun 24, 2011 | 07:28 AM
128auto's Avatar
128auto
I bought it from Fuelmoto, brand new in box, both filter and housing stamped AN, hopefully not a counterfeit lol . Taking pictures now, stay tuned!
Old Jun 24, 2011 | 07:45 AM
128auto's Avatar
128auto
Here we go, actually I am wrong, the holes are more than 1" off, omfg! From what I understand, if the base line up to the throttle body, the only thing wrong must be the air filter.
Old Jun 24, 2011 | 07:48 AM
8541hog's Avatar
8541hog
You have a BSII filter and BSI base plate
Old Jun 24, 2011 | 07:52 AM
128auto's Avatar
128auto
I thought the BS2 air filter is tapered upside down, isn't it?
