New theory on an old problem - Stock performance/slow acceleration
Can someone please explain 'pinging' and 'WOT' for someone who don't have English as a first language. What do you mean when the motors "pings"?
"only time my bike has pinged over the last week has been when I've intentionally banged it to WOT at extremely low RPM to induce it"
Thanks!
Sure, WOT is short for wide open throttle and pinging is a common term used to describe detonation and/or knocking (mostly because of the sound it makes). Whichever term is used in your neck of the woods.
Go for it, it's only a few minutes of your time and an adjustment away from back to normal.
I think I'm going to add in that 1/2 to 1 turn additional tightening just to see if performance returns to the same way it was before. I just want to verify that the adjustment is what made the difference.
Must be a change after 05, my manual has nothing about 1/2-1 turn, nor does it differentiate between carb and EFI adjustments.
One thing this thread did do was cause me to read it though...
Unless you replaced the hand grips and the curcumferance of the cable groove is bigger, then making the cable shorter or longer makes no difference in the ratio of turning the grip to the opening of the efi throttle.
The only differnce you you seem to have made is that you are now opening the throttle as soon as you turn the grip and it now goes through the full motion on the efi throttle. Of course the vacuum leak would make a difference too, adding more air and leaning out the mixture. This would cause a pinging sound under load, esp in 6th gear. It sounds like you had a lot of play in the old cable, especially with the adjusters messed up.
It sounds to me like you had enough slop in the cable to affect the opening, delayed, and then it not opening up all the way at WOT. On your old cables. Shortening or lengthening the cable has absolutely no effect on opening or closing rates. Now shortening a spring by cutting coils will make it stiffer, never softer. So I think you are just feeling what you should have felt with the bike if the cables were in good shape and adjusted right. At least now you will know how feels if the adjusters start going out again.
Your TPS moves with the throttle plate. Changing the adjustment on your cable will not move the TPS at a different rate than the throttle plate. If you are thinking as you stated that there are no mechanical changes in the FI system then you need to take the air cleaner off and look in there. When you operate the throttle the butterfly valve opens mechanically with the cable. The TPS just tells the inboard computer how far it's opened and that reading along with manifold pressure are used to calculate engine load and fuel requirement. It doesn't matter how you open the throttle, it can be a cable or by hand, the TPS will always move with the butterfly valve. In other words you theory is not true.
Now, if you actually synchronize grip input to sensor input, it's possible that the ECM actually has the capability in stock form of keeping up. But for whatever reason, the MoCo seems to have us deliberately throwing the sensor out of whack by a small amount.
The only difference you you seem to have made is that you are now opening the throttle as soon as you turn the grip and it now goes through the full motion on the efi throttle. Of course the vacuum leak would make a difference too, adding more air and leaning out the mixture. This would cause a pinging sound under load, esp in 6th gear. It sounds like you had a lot of play in the old cable, especially with the adjusters messed up.
Russ
I agree with Russ, cable adjustment has no bearing on the sensor. The TPS is mounted to the throttle body and actuated by the plate the cables hook to, cable adjustment can't change that relationship. I think you are correct on getting more performance with the adjustment because you may not have been getting WOT before.
What he is talking about is taking the lash out of the cable so the grip is more sensitive to throttle position. I have ridden 3 06 and later dynas and they all come with some cable slack from the factory. If this is removed you do get a different feeling when rolling on and off the throttle. The engine mechanically is no more powerful but the ergonomic response is way way better. I have much better control of my bike with this adjustment especially adding power in curves. But a newbie rider could get into trouble with the throttle this sensitive.
