KnN air filter
Old Jun 30, 2011 | 01:07 PM
HDJeff14's Avatar
HDJeff14
Default KnN air filter
I have a 2010 dyna fatbob and was thinking of either putting on the screaming eagle stage 1 or the KnN custom assembly. I've heard different things like the KnN is much better than the SE as in getting more horse power. I've also heard that the KnN custom assembly has had problems like bolts coming loose, leaking oil, ect. I've also heard that the KnN is washable and the SE isn't. Can anyone give some helpful advice on this matter? Thanks.
Old Jun 30, 2011 | 01:15 PM
SC-Longhair's Avatar
SC-Longhair
You can get the se backplate and buy the k&n filter for it (p/n: hd-800). That's what I have.
Old Jun 30, 2011 | 01:19 PM
cgtrigg's Avatar
cgtrigg
thats what I have too
Old Jun 30, 2011 | 01:22 PM
soft 02's Avatar
soft 02
Curios about others experience with SE filters as I have gone through 4 K&N filters.
SC-Longhair
You gotta be doing something wrong to go through 4 of them.
The SE filters are paper, and not washable.
Old Jun 30, 2011 | 01:26 PM
soft 02's Avatar
soft 02
Yep. I got 90,000 miles on the bike and ride all year round with an exposed air filter. I change it out when I can see holes in it. I was wondering if the SE non oil one holds up better. And yes I clean it per K&N instructions with only raw hose pressure and with the supplied cleaner and oil. I dont mind changing it out once a year.
Old Jun 30, 2011 | 04:26 PM
08fxdf43202's Avatar
08fxdf43202
I have no idea what K&N filter you might be talking about... I have a 90* intake with a K&N filter on it, got it used for $20.
I had a SE stage 1 intake prior to acquiring the K&N intake... ther is a noticable improvement with the K&N 90* intake.
Crank case ventilation is always an issue with after market air cleaners. You should always consuider the CCV set up with an AC mod. Here's a pic of my set up... for what it's worth:
Old Jun 30, 2011 | 07:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Put the SE intake system on my 02 FXD in 2003, back then they used K&N filters. The same filter is still on my bike, wash and reoil it prior to each riding season. The 05 FXDLI also has a K&N filter, no problems here.
Old Jun 30, 2011 | 07:43 PM
missedem's Avatar
missedem
08FXD I have to tell you that is one bad *** bike. love the wheels you have. the aircleaner setup looks just right.
Old Jul 1, 2011 | 03:30 AM
DonN's Avatar
DonN
I have the SE filter. Does anyone know if there is a big difference in airflow to the K&N? I dont want to have to retune the PCIII if there is a significant difference as mine tends to pop a lot on decel.
bigh8840
Dec 29, 2013 03:59 PM
BCguy
Dec 31, 2008 01:21 AM
ebeattie
Jul 21, 2007 01:16 PM
rpt63
Aug 12, 2006 12:40 AM
pig iron
Exhaust System Topics
13
Aug 13, 2005 12:18 AM
