SE II Air Filter
Regards,
Bill
You could swap the element for the K&N so you shouldn't run into a problem. The one that comes apart is the blue banded one.
As far as I know no one make a K&N type replacement for the 04/05 SE AC.
If you know of one please let me know and I will pass it on to the guys at the XLForum.
Take a look here http://www.knfilters.com/search/universal.aspx
They should make one for every application , maybe a call to them might give you something. You can click on the image and enter your dimentions for a part number
Here's the info I finally got back from K&N on the filter... Looks like "The Big Sucker" may be an option now
Hello,
Thank you for your interest in K&N products. Unfortunately we do not at this time offer a replacement filter for the paper filter now used by Harley.
Thank you,
Leon S. Collins
K&N Technical Support
1-800-858-3333
The statement above is intended solely for the person(s) to whom it is addressed and is not to be publicized, republished, copied or repeated unless done so in its entirety. If you are not a named recipient, you are also on notice of its status. Please notify the sender immediately by reply e-mail and then delete this message from your system. You must not disclose it to any other person, copy or distribute it or use it for any purpose.
-----Original Message-----
From: jlacasci@comcast.net [mailto:jlacasci@comcast.net]
Sent: Monday, July 18, 2005 11:27 AM
To: Tech Support
Subject: Harley-Davidson Filter replacement???
Hi,
I own a 2005 FLHTCU/I with a Harley Stage 1 kit. The kit came with a HD paper air filter PN 29442-99C, I'd like to replace this filter with a K&N filter but can not find one on your web site.
Do you have a part number to replace this filter?
Thanks,
Joe
Forget it, I just called (800) 858-3333 They said that they DO NOT manufacture the blue banded one and ALL their filters are the oiled type.
Here's the part number for the HD (K&N) replacement filter for the stage 1 upgrade PN 29442-99A . This is the oil coated K&N, NOT the blue one.
It needs a cleaner to service it PN 99883-88T
and an oiling with PN 99332-88T
Cleaning Instructions http://www.knfilters.com/clningins.htm
